    DesignSparkMechanical Vx
    13 Posts 3 Posters 14.5k Views 3 Watching
      I have found! ๐Ÿ˜„
      But not sure that will work more speedy than my first "duplicate"! ๐Ÿ˜„
      You must select strictly 3 edges!!! (1, 2, 4 don't work)
      (of course in SU it's trivial ๐Ÿ˜„
      http://s6.postimg.org/k9bmho769/pushok.gif
      • JQLJ Offline
        JQL
        Seems very good. What you imagine can be done with it? I will test it eventually... but
        www.casca.pt
        Visit us on facebook!
          It's "direct modeling" (more than Sketchup) for mechanical modeling
          but accept SKetchup file Export Import! ๐Ÿ˜„ 2014
          (whithout textures ! Allows set colors for the different colors / textures from SU )
          And perfect for something like complex Shells (molding) or Fillets for example!
          As free it's a true gem! ๐Ÿ˜„
          By Odrik
          http://i55.servimg.com/u/f55/16/30/24/60/captur16.jpg
          here the top (gutter) was modified and re-export to SKetchup
          http://i55.servimg.com/u/f55/16/30/24/60/captur15.jpg
          Gutter created by Shell
          http://i55.servimg.com/u/f55/16/30/24/60/captur19.jpg
          Post adaptation
          http://i55.servimg.com/u/f55/16/30/24/60/captur21.jpg
            PS;) thx Burr
            Select Edge then Face + Ctrl ๐Ÿ˜„
            http://s6.postimg.org/ld0c7dh75/pusho.gif
              Happy Easter! ๐Ÿ˜Ž
              DesignSpark permits to make PDF 3D !!! ๐Ÿ˜„
              And allows with a little trick to input Nurbs like STEP format from any progs like Moi for example! ๐Ÿ˜„
              A little trick for the "Only read file STEP imported"! ๐Ÿค“
              Import the STEP file
              Add a solid to the drawing (cube, cylinder, sphere, whatever).
              Right click on the top-most name of the component tree (the name of the whole thing).
              Unlock. Everything in the tree is now unlocked.
              Have fun modeling! โ˜€
              If you want the PDF 3D File, it's here! ๐Ÿ’š
                some tricks ๐Ÿ˜‰ more on my site ๐Ÿ˜„
                For reduce or increase a surface
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5682330_orig.gif
                For make a rotation an object must be previous point axe existing :gride is not sufficient!
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9026747_orig.gif
                Measures frame can be hide by click on it for have properties!
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7796022_orig.gif
                  Very exotic method for see the volume of an object! ๐Ÿ˜„
                  You must have 2 volums minimum
                  And for see the last of a serial you must copy it!!! ๐Ÿ˜ฎ
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1421979_orig.gif
                    A trick for have objects from DesignSpark Mechanical in nurbs format inside any Nurbs program! ๐Ÿ˜‰
                    Use Fusion 360 : it has format SAB !
                    As the format Rsdoc from DesignSpark Mechanical can give directly SAB format!
                    (rename myobject.rsdoc in myobject.zip, unzip it you have the file .SAB inside the folder SpaceClaim/geometry ! ๐Ÿค“
                    Fusion 360 who is Free for students, enthusiasts, hobbyists, and startups
                    Full use of Fusion 360 Ultimate for as long as you need it!
                    ๐Ÿ˜„
                      jpalm32
                      I use Design Spark PCB mostly for Electronic design. Played with this a little. Seems very good for mechanical type stuff...enclosures, metal work....
                        Always alive! ๐Ÿ˜‰ Always free
                        hhttps://www.youtube.com/watch?v=9wDUiWpmfLs
                          Tested 5.0 works fine : import export SKP (geometry)
                          For Nurbs : Import Step export SAT (with tricky tinker above but working fine) ๐Ÿค“
                          And can generate a PDF 3D! ๐Ÿ˜„
                          https://images2.imgbox.com/e8/b9/Jhux4JJb_o.gif
