    [Plugin] FredoTools::Convexify - v1.0 - 25 Feb 15
    28 Posts 9 Posters 23.3k Views 9 Watching
      Will be fine if we can exit with an actual position of the animation Explode Convexify colored view!
      (with colors or not)
      Or does exist a trick ?
      (sure I can use other thing like Explode-view, Animator, ... but that give not the colors etc...
        Seems there is a glitch!
        Glitch_Convex_V6.skp
        • gillesG Offline
          gilles
          It's seems to be relative with angular tolerance.
          • gillesG Offline
            gilles
            But I may be wrongโ€ฆ
              Even more evident for 2 simple circles extruded! ๐Ÿ˜ฎ
              Dashed lines should be the good ones!
              • fredo6F Offline
                fredo6
                Pilou,
                This is normal.
                The corresponding vertices of the inner and outer circles are not 'aligned', that is, the line joining two corresponding vertices does not go through the common center of the circles.
                This is a frequent issue when drawing co-centric circles. Because they are made of segments, it may important to keep them 'aligned'. I must say that the Circle tool does not help too much for that.
                If Convexify was 'following' your edges in the current model, the pieces would not be convex or would have to be divided in smaller chunks.
                Fredo
                  That is some ennoyous! ๐Ÿ˜„
                  So we must found a trick!
                  Because make drawings with concentric Circles or Arc-circle are very commune! ๐Ÿค“
                    Ok I found one ๐Ÿ˜„
                    Drawing concentric circles on the same alignment! ๐Ÿ˜„
                    here the red axe!
                    PS Now if you can exit during the animation for keept the position of objects & colors
                    that will be cool! ๐Ÿ˜„
                    • 2 / 2
