    [proto] 2d stencil - real line hatches
    27 Posts 11 Posters 9.8k Views 11 Watching
    • JClementsJ Offline
      JClements
      Would it be an improvement to save the hatching element as a component rather than a group so that the file size is smaller?
      • K Offline
        kaas
        I didn't go that route with this version because the plugin was initially made from a hatching-sections point of view. That involves lots of cutting of the hatches after the copy process so a lot of the components would have to be exploded.
        I do see the benefits using components for 2d elements that wouldn't have to be cut. Stuff like: cars, trees, furniture, plants etc etc. Someone also suggested if it could be done with glue/cut-components. I will have a look if this can be implemented.
        • F Offline
          function
          I do like the idea of using this as a component or block library. I always have found then native component window clunky for setting up my libraries
          • JQLJ Offline
            JQL
            πŸ‘
            www.casca.pt
            Visit us on facebook!
            • P Offline
              penaten
              Looks like over a years worth of non activity. Any further progress? Looks like a very useful concept. Is it downloadable?
              • K Offline
                kaas
                I stopped development in feb 2015 (see my 'edit' in the original post). Maybe at some point I will pick it up again (with the help of a proper coder) - it was my first ruby plugin and needs a complete overhaul. At that point it would be a payed plugin so the current code is not downloadable.
                  julyyen
                  Hi, after 6 years still not found another good real line hatches solution.
                  May I ask if there's any progress with your plugin? When you estimate we can buy it?
                  • 2 / 2
