    3DArcStudios trees work, but not grass
    2 Posts 2 Posters 382 Views 2 Watching
    • L
      LARV
      When I use the 3dArcStudios plugin Tree maker it works fine with trees (you just select and click, I like that), but when I do the same with grass it shows up as outlines, and when I render it doesn´t show at all.
      Any help?
      • ppoublanP
        ppoublan
        Hi Larv,
        Sorry for the late answer, did not see you question before.
        Probably you alredy found the answer.
        When you place grass, it is added to model in proxy mode (only skeleton lines).
        You need to redraw your tree/plants to get them in full mode and they will be rendered.
        You can switch back with one click to proxy mode once rendered, to keep your model not so big and not to slow while working on other parts of your model.
        Yours
        Pascal
