    Extension rbz maker
    38 Posts 7 Posters 6.1k Views 7 Watching
    • inteloideI Offline
      inteloide
      Hello,
      I would like to propose you my new plugin : BGSketchup_RBZ_maker
      The purpose of this plugin is to make the process of extension rbz creation easier.
      Note : This plugin is for extension authors.
      screenshot
      Once sketchup launched, click on the toolbar icon or through menu (Plugins >> BGSketchup >> RBZ maker)
      You can then choose your extension, then choose wich files to scramble/encrypt, then destination file name (currently plugin propose you the plugin name + version), then generate !
      May I have your help on :
      • the installation of gem rubyzip, to make it easier for user
      • MAC tests as I'm a PC user
      The plugin :
      Version 1.0.1
      Thank you.
      Inteloide (BGSketchup)
      Restrictions :
      -You must have Sketchup 2015 (because of rubyzip gem installation, or is there another way ???)
      -You must have the gem rubyzip installed (the rbz contains one version of it) to install it, just run in Ruby console Gem.install 'c:\toto\rubyzip', where c:\toto\ is the directory name of the gem file.
      -Your extension file structure contain a sub-folder with the same name that root extension file. Example :
      extension_toto.rb
      extension_toto/main.rb
      extension_toto/second.rb
      -This plugin require BGSketchup_Library extension (you can find it on the Pluginstore)
      Informations :
      This plugin send anonymous data to my website (just for statistic analysis). Data can be consult at BGSketchup website. If this is a problem, I can remove the feature. I include this to know how often my plugins are used, to keep motivation in creating new plugins.
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • Dan RathbunD Offline
        Dan Rathbun
        Gem.install "rubyzip"
        will install the latest version of rubyzip from the rubygems.org server.
        Pure Ruby gems (those that do not contain compiled binaries,) should work on SketchUp 2014, as it has Ruby 2.0.0 also.
        I'm not here much anymore.
        • TNTDAVIDT Offline
          TNTDAVID
          Hello
          I want to blur my fichiers.rb to protect my work, so I downloaded the Plugin BGSketchup_RBZ_maker v1.0.1.rbz
          Then I installed all additional Plugin:
          BGSketchup_Bill_of_material
          BGSketchup_Comments
          BGSketchup_Components_manager
          BGSketchup_Library
          I work with SketchUp 2014 under Windows 7 and the Plugin does not work 😕
          When I click on "Generate" nothing happens
          http://nsa33.casimages.com/img/2014/11/25/141125034946464116.jpg
          I tried to SketchUp 8 but the result is even worse because the "BGSketchup_Library_v2.0.7.rbz" file, crashes the from Sketchup startup .
          How to make the plugin work ?
          Thank you for your help.
            driven
            hi David,
            did you instal rubyzip?
            as Dan posted above, you can do it in Ruby Console with
            john
            • TNTDAVIDT Offline
              TNTDAVID
              I downloaded the file rubyzip2-2.0.2.gem
              To decompress the contents I renamed the extension zip:
              http://nsa34.casimages.com/img/2014/11/25/141125063403401324.jpg
              What now for all these files ?
              • TNTDAVIDT Offline
                TNTDAVID
                http://nsa33.casimages.com/img/2014/11/25/14112507281221315.jpg
                I have not all inclusive 😕
                Can you detail the procedure ?
                thank you
                • TNTDAVIDT Offline
                  TNTDAVID
                  This does not work yet :
                  http://nsa33.casimages.com/img/2014/11/25/141125081338514942.jpg
                    driven
                    I only just tried it myself and I had to use
                    require('zip')
                    than that returns true...
                    I'll have a look at the plugins code to see what it uses
                      driven
                      the plugin uses require 'zip' so that bit should work...
                      the other thing I'd point out is you should not include the .skb files in your rbz...
                      john
                        driven
                        you don't need them,
                        do it from 'Ruby Console' in Sketchup, it's much easier...
                        then to test it's working type
                        require("zip")
                        #EDIT; had rubyzip
                        it should => true
                        then try this plugin again...
                        john
                          driven
                          1: open "Ruby Console"
                          2: paste in this
                          and enter...
                          3: if no errors paste in this
                          require("zip")
                          #EDIT; had rubyzip
                          and enter...
                          4: if no errors, try this plugin...
                          or report back...
                          • TNTDAVIDT Offline
                            TNTDAVID
                            thank you
                            require ('zip') worked well
                            I can now run Extension RBZ maker !
                            My plugin does not contain files Skb but SKP.
                            I noticed that the ruby script codes are protected but not the components used by my Plugin.
                            Is there a way to protect the SKP files ?
                              driven
                              your image above shows both in the folder
                              No, even if there was, once it's in the model people can do anything they want...
                                Dan Rathbun
                                Do not use that. It is actually an older code fork than just plain rubyzip v1.1.6.
                                (Not sure why the author left it up on rubygems.org. It is a kind of beta version for Ruby higher than 1.8, but was abandoned. The original v1 code trunk was fixed to run in 1.9+ Ruby.)
                                  driven
                                  @dan what's happening with require 'rubyzip' v require 'zip' ?
                                    Dan Rathbun
                                    The RubyGems extension modifies the global require() method so that it can load gems (and push their paths into $LOAD_PATH,) and if need be, install them first from whatever gem servers are registered. (By default only rubygems.org is registered.)
                                    So [important], this: require 'rubyzip', is actually saying "require the gem named 'rubyzip'", not "require the file named 'rubyzip.rb'".
                                    Once the gem library is installed and loaded, it can be used as it normally would, had it been a standard extension, in Ruby's library.
                                    Hence, the require("zip") which actually makes sure that the
                                    "#{ENV['GEM_PATH']}/gems/rubyzip-v1.1.6/lib/zip.rb" file is loaded.
                                    This works because the override of the global require(), by the RubyGems extension, has push the rubyzip lib into the $LOAD_PATH array. Ie:
                                    "#{ENV['GEM_PATH']}/gems/rubyzip-v1.1.6/lib/"
                                    But I like to wrap in begin. .. rescue, just in case.
                                      driven
                                      cheers dan,
                                      another ?
                                      in your example code wont require 'rubyzip' always fail, even when require 'zip' returns true?
                                      john
                                        Dan Rathbun
                                        Hmmm.. OH I see.. even though, given the following:
                                        Ref:
                                        When RubyGems is required, Kernel#require is replaced with our own which
                                        is capable of loading gems on demand.
                                        When you call require 'x', this is what happens:
                                        * If the file can be loaded from the existing Ruby loadpath, it is.
                                        * Otherwise, installed gems are searched for a file that matches.
                                        If it's found in gem 'y', that gem is activated (added to the
                                        loadpath).
                                        The normal require functionality of returning false if
                                        that file has already been loaded is preserved.
                                        Something I overlooked was, that in most gems, the gem "name" is the same as the gem loader script name.
                                        But in this gem, the name is "rubyzip", but the loader script name is "zip.rb".
                                        So what the overridden require does is, look for a loader script named "rubyzip.rb" and it will NEVER find it, so a LoadError exception will be raised, always, even if the gem is already installed, and even if it is already loaded.
                                        And then my rescue LoadError clause will be fired.
                                        This doesn't hurt the first time, as if SketchUp is started normally and Rubygems is loaded and working.. the "rubyzip" gem will get installed and/or initialized by my LoadError clause.
                                        OK I need to change things a bit. I used to have a bail out " return true if defined?(Zip)" as the first line, removed it when I tried to load the "zip/filesystem" extension in the same methoid. I moved that to it's own method, so I'll put the short-circuit return line back in.
                                        Then I may need a different basic test other than require("rubyzip").
                                        I am not actually using the return value of require("rubyzip") to make any boolean decisions.
                                        Perhaps just require("zip") ?
                                        • P Offline
                                          pgarmyn
                                          RBZ-files are not intended to protect code. Any unzip program can be used the convert them back to the original files.
                                          Only the scrambler will give limited protection.
                                          • TNTDAVIDT Offline
                                            TNTDAVID
                                            pgarmyn
                                            I can assure you that RBZ maker convert my file "rb" in "rbs" !
                                            Although the RBZ file can be decompressed the code is protected 👍
                                            driven
                                            You're right for the skb! This is fixed now 😉
                                            • 1 / 2
