    Extension rbz maker
    38 Posts 7 Posters 5.8k Views 7 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      http://nsa33.casimages.com/img/2014/11/25/14112507281221315.jpg
      I have not all inclusive 😕
      Can you detail the procedure ?
      thank you
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • TNTDAVIDT Offline
        TNTDAVID
        This does not work yet :
        http://nsa33.casimages.com/img/2014/11/25/141125081338514942.jpg
          driven
          I only just tried it myself and I had to use
          require('zip')
          than that returns true...
          I'll have a look at the plugins code to see what it uses
            driven
            the plugin uses require 'zip' so that bit should work...
            the other thing I'd point out is you should not include the .skb files in your rbz...
              driven
              @tntdavid said:
              What now for all these files ?
              you don't need them,
              do it from 'Ruby Console' in Sketchup, it's much easier...
              then to test it's working type
              require("zip")
              #EDIT; had rubyzip
              it should => true
              then try this plugin again...
                driven
                1: open "Ruby Console"
                2: paste in this
                Gem.install "rubyzip"
                and enter...
                3: if no errors paste in this
                require("zip")
                #EDIT; had rubyzip
                and enter...
                4: if no errors, try this plugin...
                or report back...
                • TNTDAVIDT Offline
                  TNTDAVID
                  thank you
                  require ('zip') worked well
                  I can now run Extension RBZ maker !
                  My plugin does not contain files Skb but SKP.
                  I noticed that the ruby script codes are protected but not the components used by my Plugin.
                  Is there a way to protect the SKP files ?
                    driven
                    your image above shows both in the folder
                    No, even if there was, once it's in the model people can do anything they want...
                    • Dan RathbunD Offline
                      Dan Rathbun
                      @tntdavid said:
                      I downloaded the file rubyzip2-2.0.2.gem
                      Do not use that. It is actually an older code fork than just plain rubyzip v1.1.6.
                      (Not sure why the author left it up on rubygems.org. It is a kind of beta version for Ruby higher than 1.8, but was abandoned. The original v1 code trunk was fixed to run in 1.9+ Ruby.)
                      I'm not here much anymore.
                        driven
                        @dan what's happening with require 'rubyzip' v require 'zip' ?
                          Dan Rathbun
                          The RubyGems extension modifies the global require() method so that it can load gems (and push their paths into $LOAD_PATH,) and if need be, install them first from whatever gem servers are registered. (By default only rubygems.org is registered.)
                          So [important], this: require 'rubyzip', is actually saying "require the gem named 'rubyzip'", not "require the file named 'rubyzip.rb'".
                          Once the gem library is installed and loaded, it can be used as it normally would, had it been a standard extension, in Ruby's library.
                          Hence, the require("zip") which actually makes sure that the
                          "#{ENV['GEM_PATH']}/gems/rubyzip-v1.1.6/lib/zip.rb" file is loaded.
                          This works because the override of the global require(), by the RubyGems extension, has push the rubyzip lib into the $LOAD_PATH array. Ie:
                          "#{ENV['GEM_PATH']}/gems/rubyzip-v1.1.6/lib/"
                          But I like to wrap in begin. .. rescue, just in case.
                            driven
                            cheers dan,
                            another ?
                            in your example code wont require 'rubyzip' always fail, even when require 'zip' returns true?
                              Dan Rathbun
                              Hmmm.. OH I see.. even though, given the following:
                              Ref:
                              When RubyGems is required, Kernel#require is replaced with our own which
                              is capable of loading gems on demand.
                              When you call require 'x', this is what happens:
                              * If the file can be loaded from the existing Ruby loadpath, it is.
                              * Otherwise, installed gems are searched for a file that matches.
                              If it's found in gem 'y', that gem is activated (added to the
                              loadpath).
                              The normal require functionality of returning false if
                              that file has already been loaded is preserved.
                              Something I overlooked was, that in most gems, the gem "name" is the same as the gem loader script name.
                              But in this gem, the name is "rubyzip", but the loader script name is "zip.rb".
                              So what the overridden require does is, look for a loader script named "rubyzip.rb" and it will NEVER find it, so a LoadError exception will be raised, always, even if the gem is already installed, and even if it is already loaded.
                              And then my rescue LoadError clause will be fired.
                              This doesn't hurt the first time, as if SketchUp is started normally and Rubygems is loaded and working.. the "rubyzip" gem will get installed and/or initialized by my LoadError clause.
                              OK I need to change things a bit. I used to have a bail out " return true if defined?(Zip)" as the first line, removed it when I tried to load the "zip/filesystem" extension in the same methoid. I moved that to it's own method, so I'll put the short-circuit return line back in.
                              Then I may need a different basic test other than require("rubyzip").
                              I am not actually using the return value of require("rubyzip") to make any boolean decisions.
                              Perhaps just require("zip") ?
                                pgarmyn
                                @tntdavid said:
                                I want to blur my fichiers.rb to protect my work, so I downloaded the Plugin BGSketchup_RBZ_maker v1.0.1.rbz
                                RBZ-files are not intended to protect code. Any unzip program can be used the convert them back to the original files.
                                Only the scrambler will give limited protection.
                                • TNTDAVIDT Offline
                                  TNTDAVID
                                  pgarmyn
                                  I can assure you that RBZ maker convert my file "rb" in "rbs" !
                                  Although the RBZ file can be decompressed the code is protected 👍
                                  driven
                                  You're right for the skb! This is fixed now 😉
                                  • TNTDAVIDT Offline
                                    TNTDAVID
                                    I just noticed a very annoying problem !
                                    RBZ maker produces non-compatible files rbs with Sketchup 8 😞
                                    I think many users are still under licenses "Sketchup 8" and wishes propose a PLUGIN which works for a maximum of users.
                                    Is there an alternative to produce rbs files ?
                                      driven
                                      what's the error message on v8 say?
                                      I'd be surprised if the .rbs is unusable, does it run as a .rb on the same machine?
                                      have DC's been enabled on that machine?
                                        Dan Rathbun
                                        Make sure your files are UTF-8 Encoded Without BOM.
                                        • TNTDAVIDT Offline
                                          TNTDAVID
                                          There is no error message the launch of Sketchup !
                                          Error 01: The toolbar will no longer display the images on the icons.
                                          Error 02: The relationship between icons and components is lost.
                                            driven
                                            are you still using
                                             path_to_components = File.join(File.dirname(__FILE__), 'Components')
                                            I'm unsure if that works from inside a rbs, I remember there was some problem with it...
