    Extension RBZ maker
    6 Posts 3 Posters 1.3k Views 3 Watching
    • inteloideI Offline
      inteloide
      Hello,
      I would like to propose you my new plugin : BGSketchup_RBZ_maker
      The purpose of this plugin is to make the process of extension rbz creation easier.
      Note : This plugin is for extension authors.
      Screenshot
      Once sketchup launched, click on the toolbar icon or through menu (Plugins >> BGSketchup >> RBZ maker)
      You can then choose your extension, then choose wich files to scramble/encrypt, then destination file name (currently plugin propose you the plugin name + version), then generate !
      May I have your help on :
      • the installation of gem rubyzip, to make it easier for user
      • MAC tests as I'm a PC user
      The plugin :
      The plugin version 1.0.1
      Thank you.
      Inteloide (BGSketchup)
      Restrictions :
      -You must have Sketchup 2015 (because of rubyzip gem installation, or is there another way ???)
      -You must have the gem rubyzip installed (the rbz contains one version of it) to install it, just run in Ruby console Gem.install 'c:\toto\rubyzip', where c:\toto\ is the directory name of the gem file.
      -Your extension file structure contain a sub-folder with the same name that root extension file. Example :
      extension_toto.rb
      extension_toto/main.rb
      extension_toto/second.rb
      -This plugin require BGSketchup_Library extension (you can find it on the Pluginstore)
      Informations :
      This plugin send anonymous data to my website (just for statistic analysis). Data can be consult at BGSketchup website
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        driven
        I've got a mac rbz maker that make 'windows safe' .rbz
        I'll PM it if you want to have a look
        john
          inteloide
          john
          Hello Driven,
          Yes please. this would be interesting for me. Are you the author of this plugin ?
          Thank you
          Inteloide
            inteloide
            Hello,
            Just post version 1.0.1, which remember which file to encrypt.
            (Hey I'm quite surprised plugin authors don't rush on it (only 3 downloads of 1.0.0) ! For me this is so much more easy to create extension using this plugin ! Or may be like driven, some of you developped your own solution to make it easier ??)
            Inteloide
            • greenskpG Offline
              greenskp
              Thank you for this amazing tool.
              I am new in the ruby world and don't know how figure out.
              I have installed your plugin - 1.0.6 version - and the Gem but Ruby Console give me an error:
              Error; #<TypeError; superclass mismatch for class StreamableStream>
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/rubyzip-1.1.6/lib/zip/streamable_stream.rb;2;in `<module;Zip>'
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/rubyzip-1.1.6/lib/zip/streamable_stream.rb;1;in `<top (required)>'
              C;/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;45;in `require'
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Gems64/gems/rubyzip-1.1.6/lib/zip.rb;26;in `<top (required)>'
              C;/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;110;in `require'
              C;/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;110;in `rescue in require'
              C;/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;35;in `require'
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/BGSketchup_RBZ_maker/RBZ_maker.rb;145;in `generate_rbz'
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/BGSketchup_RBZ_maker/RBZ_maker.rb;118;in `generate'
              C;/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/BGSketchup_RBZ_maker/RBZ_maker.rb;39;in `block in show_hide_window'
              SketchUp;1;in `call'
              • greenskpG Offline
                greenskp
                Another thing.....the default installation is fine but an installation with a custom folder always ask me to install BGSketchup Library but the library is already installed in same folder.
                I am using
                require_all('path\to\custom\folder')
                inside default plugins folder.
                http://i.imgur.com/eFG6W54.jpg
