    REQ: Checking if components (solids) intersect
    22 Posts 5 Posters 3.2k Views 5 Watching
    • G Offline
      glro
      @pgarmyn said:
      @giro
      		model=Sketchup.active_model
      > 		ss=model.selection
      > 		ents=model.active_entities
      > 		ss.clear
      > 		gps=ents.grep(Sketchup;;Group)
      > 		ins=ents.grep(Sketchup;;ComponentInstance)
      > 		ens=gps+ins
      > 		ens.uniq!
      > 		ens.compact!
      > 		for i in (0..ens.length-2)  ############changed from length-1 to length-2
      > 			for j in ((i+1)..ens.length-1)
      > 				if TIG.intersect?(ens[i], ens[j])
      > 					ss.add(ens[i])
      > 					ss.add(ens[j])
      > 				end
      > 			end
      > 		end
      >         puts "Any intersecting groups/component-instances are highlighted..."
      I think, in this case, the last TIG.intersect?(ens[i], ens[j]) is with i=length-2 and j=length-1
      Otherwise j = i+1 will become ens.length : for 5 elements (0 to 4) in ens, j will be 5.
      i tried to run this code in sketchup 15 64 bits, thinking it could run faster than is sketchup 8
      All the contrary
      it is much slower in sketchup 15 64 bits... (about 10 times...)
      i am very disapointed
      am i the only one to experience that?
        Bobvandevoort
        This is my version of the srcipt for now that seems to work for all non nested component instances
        module Bob
        # Huge parts of this code were written by TIG this is a sligthly modified version
        	def self.intersectBob?(e1=nil, e2=nil)
        		mod = Sketchup.active_model # Open model
        		ent = mod.entities # All entities in model
        		instance1 = e1 #sel[0]
        		instance2 = e2 #sel[1]
        		ci_def = instance1.definition
        		tr1 = instance1.transformation
        		test1 = Sketchup.active_model.entities.add_instance ci_def, tr1
        		ci_def2 = instance2.definition
        		tr2 = instance2.transformation
        		test2 = Sketchup.active_model.entities.add_instance ci_def2, tr2
        		result = test1.intersect(test2)
        		cnt = result.entities.count
        		if  cnt > 0
        			int=true
        			result.definition.entities.each {|ent|
        			if ent.is_a? Sketchup;;Face
        				ent.material = 'red' #Sketchup;;Color.new(255, 0, 0)
        			end}
        		else
        		int=false
        	return int
        	#def self.del()	#does not work like this typing Bob.del into the ruby console, meaning result has to be changed from local to global variable but I don't know how yet
        	#result.erase!
        	#end
        	def self.intersectALL()
        		ss=model.selection
        		ss.clear
        		ens=gps+ins
        		ens.uniq!
        		ens.compact!
        		(ens.length).times{|i|
        			(ens.length).times{|j|
        				next if j<=i
        				if self.intersectBob?(ens[i], ens[j])
        					ss.add(ens[i])
        					ss.add(ens[j])
        		puts "Any intersecting component-instances are highlighted..."
        In this script I still need to fix the deleting function which later will have to be added to an observer class so as soon as another is clicked (or a button is pressed) the resulting intersection is deleted.
        The more important function that still has to be added is that it does the check for all the nested components (and possibly groups).
        @giro
        I only have the 32 bits version so can't say
        • 2 / 2
