    Floating objects
    2 Posts 1 Posters 7.2k Views 1 Watching
      deskpilot
      Hi Guys. I've finally got SP working with Su2014 and have applied a servo joint to my aircraft retractable nose-wheel and leg-assembly model. Too difficult to insert image.(need a copy and paste facility) However, when I toggle 'Play', my assembly loses contact with it's rotational axis and floats away from what should be it's location axle. I can still make it retract as required, but not around it's fixed point.
      It is anchored to a 'static' 'box' for this trial and I have it's status as a 'frozen' default shape.
      Where am I going wrong?
      Cheers, Doug, aka Deskpilot
        deskpilot
        Fixed. Made the under-carriage assembly 'magnetic'. Works like my dream now.
