    Change variable after certain number of loops
    14 Posts 5 Posters 1.0k Views 5 Watching
      davesexcel
      I am trying to figure out this loop,
      when i=e then I want b=0.5
      Thanks,
      Dave
      UI.menu("PlugIns").add_item("Draw stairs") { draw_stairs }
      def draw_stairs
      prompts = ["length", "Run","height","Rise","Total Rises"]
          defaults = [36.0,10.0,1.0,7.75,7]
          input = UI.inputbox prompts, defaults, "Tread."
          if input == false
          UI.messagebox("All Must Be Entered")
          else
            a,b,c,d,e=input
          #UI.messagebox("Tread input accepted!, #{input}!")
          ent = Sketchup.active_model.entities
      for i in 0..e-1
      [b]#if i=e-1 then b=0.5[/b]
        ent.add_line [0,(b+1)+i*b,0+i*d-1],[0,(1.5+i*b),0+i*d-1]
        ent.add_line [0,1.5+i*b,0+i*d-1],[0,1.5+i*b,-d+(i*d)-1]
       ent.add_line [0,1+i*b,0+i*d-1],[0,1+i*b,-d+(i*d)-1]
      ent.add_line [0,1+i*b,-d+(i*d)-1],[0,1.5+i*b,-d+(i*d)-1]
        ent.add_line [0,1+i*b,-1+i*d],[0,0.5+i*b,-1+i*d]
        ent.add_arc [0,0.5+i*b,-c/2.0+(i*d)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
          ent.add_line [0,0.5+i*b,0+i*d],[0,b+(i*b)+1,0+i*d]
          edg=ent.add_line [0,b+1+i*b,-c+i*d],[0,b+1+i*b,0+i*d]
           edg.find_faces; face=edg.faces[0]
          # #face = ent.add_face [0,0,0], [a,0,0], [a,b,0], [0,b,0]
          #face.reverse!
           face.pushpull -a
      	# edg.soft="true"
      	 #group1 = ent.add_group face.all_connected
            #group1_copy = group1.parent.entities.add_instance(group1.entities.parent, group.transformation)
      • sdmitchS Offline
        sdmitch
        Did you mean when i=e? Because i is never going to equal d(rise).
        http://sdmitch.blogspot.com/
          davesexcel
          Yep, you are correct,
          I wonder if it might be easier to find the back face and pushpull it e-(e-0.5)
          How do you pushpull the back face only?
          • sdmitchS Offline
            sdmitch
            I'm not sure which one is the "back" face is but you just need face criteria that only matches the one of interest. Like in the case of the edges to be softened, they had to be of length "a".
            By the way, e-(e-0.5) = 0.5.
              davesexcel
              Oh ya, I guess it would be e-0.5 so it would have to be pushpulled -(e-0.5)
              I keep getting pushpull stuck in the head.
              What I am looking for is on the last loop make b=0.5
              I have tried adding k into the mix mix with no success, now b is 0.5 on all the loops.
                      a,b,c,d,e=input
                      k = 0 #<<--- start k=0
                      for i in 0..e-1
                      if k=e-1 then #<<<----if k=e-1
                      b = 0.5
                      end#<<<---
                      ent.add_line [0,(b+1)+i*b,0+i*d-1], [0,(1.5+i*b),0+i*d-1]
                      ent.add_line [0,1.5+i*b,0+i*d-1], [0,1.5+i*b,-d+(i*d)-1]
                      ent.add_line [0,1+i*b,0+i*d-1], [0,1+i*b,-d+(i*d)-1]
                      ent.add_line [0,1+i*b,-d+(i*d)-1], [0,1.5+i*b,-d+(i*d)-1]
                      edg = ent.add_line [0,1+i*b,-1+i*d],[0,0.5+i*b,-1+i*d];vrt1=edg.end#<-----
                      edg = ent.add_line [0,0.5+i*b,0+i*d],[0,b+(i*b)+1,0+i*d];vrt2=edg.start#<----_
                      face.pushpull -a
                      edgs=vrt1.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
                      edgs=vrt2.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
                      k=k+1#<<---add 1 to k
                davesexcel
                Alright I can get the b=0.5 on the last loop but can't get it to the correct location, because I changed b to 0.5 !!!.
                        a,b,c,d,e=input
                        for i in 0..e-1
                        if k>e-2 then #<<<----if k=e-1
                        b = 0.5
                        end#<<<---
                		k=k+1
                        ent.add_arc [0,0.5+i*b,-c/2.0+(i*d)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,12
                        face.pushpull -a
                • sdmitchS Offline
                  sdmitch
                  Two things.
                  The if k=e-1 failed because the proper syntax is if k==e-1.
                  Because you use a multiple of b to define the location, changing it for the last one requires a different formula. Shorten the For loop to e-2 and copy and modify the code in the loop to create the last step with b=0.5.
                    davesexcel
                    Excellent, thanks for the suggestion...it worked.
                    Just a side note, is there a "clear All" code that can run at the beginning of this code?
                    for example
                    ` clear_all#< clears everything on the screen.
                    prompts = ["length", "width","height","Rise"]
                    defaults = [36.0,10.0,1.0,7.75]
                    if input == false
                    else
                    a,b,c=input
                    ent.add_line [0,b-c/2,0],[0,0,0]
                    ent.add_arc [0,0,c/2.0],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
                    ent.add_line [0,0,c],[0,b-c/2,c]
                    edg=ent.add_line [0,b-c/2,c],[0,b-c/2,0]
                    #face.reverse!
                    face.pushpull -a`
                    • jolranJ Offline
                      jolran
                      One idea is starting using groups to organize your geometry.
                      Clearing everything on the screen, sounds like a dangerous approach to me.
                      Just a simple tip..
                      ents = Sketchup.active_model.entities
                      gp = ents.add_group
                      ent = gp.entities
                      • tt_suT Offline
                        tt_su
                        for example
                        In SU2014 and up: just type cls
                          davesexcel
                          Just a simple tip..
                          gp = ents.add_group
                          ent = gp.entities
                          Thanks,
                          I'm just trying to find a way not to have to keep pressing 'Ctrl & "A" then delete, every time I want to test a code.
                            driven
                            for testingyour code you can use
                            Sketchup.active_model.entities.clear!
                            but have another look at TT's notes and the API at wrapping your code in a Start Operation...
                            then use your Undo shortcut...
                              davesexcel
                              Right on thanks.
                              • jolranJ Offline
                                jolran
                                Thanks,
                                Ah, right! Understood.
                                Well TT and Driven got the answers already.
                                Another handy plugin is using Alex Ruby-code editor.
                                You don't have to wrap code in Start Operation cause there's an inbuilt Play and Undo button. Very useful for testing loose code snippets. Copy and paste from Notepad for ex..
