    Change variable after certain number of loops
    14 Posts 5 Posters 1.2k Views 5 Watching
      davesexcel
      @sdmitch said:
      Did you mean when i=e? Because i is never going to equal d(rise).
      Yep, you are correct,
      I wonder if it might be easier to find the back face and pushpull it e-(e-0.5)
      How do you pushpull the back face only?
      • sdmitchS Offline
        sdmitch
        I'm not sure which one is the "back" face is but you just need face criteria that only matches the one of interest. Like in the case of the edges to be softened, they had to be of length "a".
        By the way, e-(e-0.5) = 0.5.
        http://sdmitch.blogspot.com/
          davesexcel
          Oh ya, I guess it would be e-0.5 so it would have to be pushpulled -(e-0.5)
          I keep getting pushpull stuck in the head.
          What I am looking for is on the last loop make b=0.5
          I have tried adding k into the mix mix with no success, now b is 0.5 on all the loops.
              prompts = ["length", "Run","height","Rise","Total Rises"]
              defaults = [36.0,10.0,1.0,7.75,7]
              input = UI.inputbox prompts, defaults, "Tread."
                  a,b,c,d,e=input
                  k = 0 #<<--- start k=0
                  ent = Sketchup.active_model.entities
                  for i in 0..e-1
                  if k=e-1 then #<<<----if k=e-1
                  b = 0.5
                  end#<<<---
                  ent.add_line [0,(b+1)+i*b,0+i*d-1], [0,(1.5+i*b),0+i*d-1]
                  ent.add_line [0,1.5+i*b,0+i*d-1], [0,1.5+i*b,-d+(i*d)-1]
                  ent.add_line [0,1+i*b,0+i*d-1], [0,1+i*b,-d+(i*d)-1]
                  ent.add_line [0,1+i*b,-d+(i*d)-1], [0,1.5+i*b,-d+(i*d)-1]
                  edg = ent.add_line [0,1+i*b,-1+i*d],[0,0.5+i*b,-1+i*d];vrt1=edg.end#<-----
                  ent.add_arc [0,0.5+i*b,-c/2.0+(i*d)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
                  edg = ent.add_line [0,0.5+i*b,0+i*d],[0,b+(i*b)+1,0+i*d];vrt2=edg.start#<----_
                  edg=ent.add_line [0,b+1+i*b,-c+i*d],[0,b+1+i*b,0+i*d]
                  edg.find_faces; face=edg.faces[0]
                  face.pushpull -a
                  edgs=vrt1.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
                  edgs=vrt2.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
                      #group1 = ent.add_group face.all_connected
                  k=k+1#<<---add 1 to k
            davesexcel
            Alright I can get the b=0.5 on the last loop but can't get it to the correct location, because I changed b to 0.5 !!!.
                    a,b,c,d,e=input
                    for i in 0..e-1
                    if k>e-2 then #<<<----if k=e-1
                    b = 0.5
                    end#<<<---
            		k=k+1
                    ent.add_arc [0,0.5+i*b,-c/2.0+(i*d)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,12
                    face.pushpull -a
            • sdmitchS Offline
              sdmitch
              Two things.
              The if k=e-1 failed because the proper syntax is if k==e-1.
              Because you use a multiple of b to define the location, changing it for the last one requires a different formula. Shorten the For loop to e-2 and copy and modify the code in the loop to create the last step with b=0.5.
                davesexcel
                Excellent, thanks for the suggestion...it worked.
                Just a side note, is there a "clear All" code that can run at the beginning of this code?
                for example
                ` clear_all#< clears everything on the screen.
                prompts = ["length", "width","height","Rise"]
                defaults = [36.0,10.0,1.0,7.75]
                if input == false
                UI.messagebox("All Must Be Entered")
                else
                a,b,c=input
                #UI.messagebox("Tread input accepted!, #{input}!")
                ent.add_line [0,b-c/2,0],[0,0,0]
                ent.add_arc [0,0,c/2.0],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
                ent.add_line [0,0,c],[0,b-c/2,c]
                edg=ent.add_line [0,b-c/2,c],[0,b-c/2,0]
                #face = ent.add_face [0,0,0], [a,0,0], [a,b,0], [0,b,0]
                #face.reverse!
                face.pushpull -a`
                • jolranJ Offline
                  jolran
                  One idea is starting using groups to organize your geometry.
                  Clearing everything on the screen, sounds like a dangerous approach to me.
                  Just a simple tip..
                  ents = Sketchup.active_model.entities
                  gp = ents.add_group
                  ent = gp.entities
                  • tt_suT Offline
                    tt_su
                    for example
                    In SU2014 and up: just type cls
                      davesexcel
                      Just a simple tip..
                      gp = ents.add_group
                      ent = gp.entities
                      Thanks,
                      I'm just trying to find a way not to have to keep pressing 'Ctrl & "A" then delete, every time I want to test a code.
                        driven
                        for testingyour code you can use
                        Sketchup.active_model.entities.clear!
                        but have another look at TT's notes and the API at wrapping your code in a Start Operation...
                        then use your Undo shortcut...
                          davesexcel
                          Right on thanks.
                          • jolranJ Offline
                            jolran
                            Thanks,
                            Ah, right! Understood.
                            Well TT and Driven got the answers already.
                            Another handy plugin is using Alex Ruby-code editor.
                            You don't have to wrap code in Start Operation cause there's an inbuilt Play and Undo button. Very useful for testing loose code snippets. Copy and paste from Notepad for ex..
