    Smooth Line after push/pull
    4 Posts 3 Posters 447 Views 3 Watching
      davesexcel
      Hello,
      When using the below code, how do I smooth the edges?
      ` prompts = ["length", "Run","height","Rise","Total Rises"]
      defaults = [36.0,10.0,1.0,7.75,7]
      input = UI.inputbox prompts, defaults, "Tread."
      if input == false
      UI.messagebox("All Must Be Entered")
      else
        a,b,c,d,e=input
      #UI.messagebox("Tread input accepted!, #{input}!")
      ent = Sketchup.active_model.entities
      for i in 0..e-1
      ent.add_line [0,(b+1)+ib,0+id-1],[0,(1.5+ib),0+id-1]
      ent.add_line [0,1.5+ib,0+id-1],[0,1.5+ib,-d+(id)-1]
      ent.add_line [0,1+ib,0+id-1],[0,1+ib,-d+(id)-1]
      ent.add_line [0,1+ib,-d+(id)-1],[0,1.5+ib,-d+(id)-1]
      ent.add_line [0,1+ib,-1+id],[0,0.5+ib,-1+id]
      ent.add_arc [0,0.5+ib,-c/2.0+(id)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
      ent.add_line [0,0.5+ib,0+id],[0,b+(ib)+1,0+id]
      edg=ent.add_line [0,b+1+ib,-c+id],[0,b+1+ib,0+id]
      edg.find_faces; face=edg.faces[0]
      # #face = ent.add_face [0,0,0], [a,0,0], [a,b,0], [0,b,0]
      #face.reverse!
       face.pushpull -a
      # edg.soft="true"
       #group1 = ent.add_group face.all_connected
        #group1_copy = group1.parent.entities.add_instance(group1.entities.parent, group.transformation)`
      Before Smooth
      https://drive.google.com/file/d/0ByXxMRXssekcaDdGRTJaN013dHc/view?usp=sharing
      After Smooth
      https://drive.google.com/file/d/0ByXxMRXssekcNC1GOWxRQTZWMmM/view?usp=sharing
      edg.soft="true" doesn't appear to do anything
      • sdmitchS Offline
        sdmitch
        @davesexcel said:
        Hello,
        if input == false
        else
          a,b,c,d,e=input
        for i in 0..e-1
        #face.reverse!
         face.pushpull -a
        edg.soft="true"
        Before Smooth
        After Smooth
        #<----- where changes and additions were made
        if input == false
        else
        a,b,c,d,e=input
        for i in 0..e-1
        ent.add_line [0,(b+1)+i*b,0+i*d-1],[0,(1.5+i*b),0+i*d-1]
        ent.add_line [0,1.5+i*b,0+i*d-1],[0,1.5+i*b,-d+(i*d)-1]
        ent.add_line [0,1+i*b,0+i*d-1],[0,1+i*b,-d+(i*d)-1]
        ent.add_line [0,1+i*b,-d+(i*d)-1],[0,1.5+i*b,-d+(i*d)-1]
        edg = ent.add_line [0,1+i*b,-1+i*d],[0,0.5+i*b,-1+i*d];vrt1=edg.end#<-----
        ent.add_arc [0,0.5+i*b,-c/2.0+(i*d)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,20
        edg = ent.add_line [0,0.5+i*b,0+i*d],[0,b+(i*b)+1,0+i*d];vrt2=edg.start#<----_
        edg=ent.add_line [0,b+1+i*b,-c+i*d],[0,b+1+i*b,0+i*d]
        #face.reverse!
        face.pushpull -a
        edgs=vrt1.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
        edgs=vrt2.edges.reject!{|e| e.length<a};edgs[0].soft=true#<-----
        # edg.soft="true"
        http://sdmitch.blogspot.com/
        • K Offline
          ktkoh
          sdmitch
          I am trying to learn from you code. How is the smoothing only applied to the edges created by the add arc? It needs some English description if you will!!
          Keith
          • sdmitchS Offline
            sdmitch
            @ktkoh said:
            sdmitch
            Keith
            I save the vertices, vrt1 and vrt2, at the beginning and end of the arc. Then I look at all the edges associated with those vertices and eliminate all that are not the proper length. This leaves me with a single edge that is softened.
