    Npr fly around videos
    30 Posts 9 Posters 3.2k Views 9 Watching
    • pmolsonP
      pmolson
      I have a client that likes to see Her designs in a npr format as fly around videos. It took a little head scratching, but I was able to come up with a process that meets her needs. Still trying to get them a bit smoother like a real movie, but not quite there. It has been fun.
      Thought I would share. [highlight=#ffff80:2t9dydjd](new video at bottom of thread)[/highlight:2t9dydjd]
      I am just now uploading them to youtube so I will add more as I get them ready.
      I think there may be a way to embed this video...I will try to figure that out.
      p
      • Bryan KB
        Very impressive! Well done! πŸ‘
        • bazB
          baz
          Yes, getting the choppiness gone is hard, mostly a matter of more fps I believe.
          Here is a very similar attempt I did a couple of years ago to show off the landscape design. BTW the two house styles couldn't be more different πŸ˜„
          http://youtu.be/sxoo-xkI8ds
          PS: Excuse the music 😳
          • pmolsonP
            pmolson
            Thanks.
            Baz, your video seems a bit smoother than mine. I am using 30 fps. What was yours at?
            • pbacotP
              I am jealous. Cool projects and videos!
              • KrisidiousK
                Krisidious
                Beautiful house Paul...
                By: Kristoff Rand
                • pmolsonP
                  pmolson
                  Thanks Kristoff, I should clarify that I am not the designer of these homes, I am just the guy that turns the designs into 3d models.
                  The videos purposfully have the designers name and copyright info. I hope it is clear enough because it is not my intent to take credit for others designs...or the blame πŸ˜‰
                  p
                  • pmolsonP
                    pmolson
                    pbacot, Thanks...Yeah I feel pretty lucky to play with these big guys.
                    Mr.obrien, Thanks for embedding the links...I see you left the code that you used visible. I should probably be able to figure out how to do it with that clue...but...Do I just copy that code and paste it into the thread with my url placed in the "videa url goes here" spot?
                    Hey! it worked. I am a genius! πŸ˜†
                    • KrisidiousK
                      Krisidious
                      Well, you brought it to life. and you did a great job.
                      By: Kristoff Rand
                      • bazB
                        baz
                        @pmolson said:
                        Thanks.
                        I wouldn't agree necessarily smoother, but maybe the scene transitions are a bit better.
                        Mine was actually 24fps. Model info settings were: Scene Transitions= 5 sec. Scene Delay = 1 sec.
                        Total of 3500 images into Premiere Elements.
                        This was a quick and dirty to meet a deadline, and I haven't pursued it since, so I am interested in following your progress.
                        Cheers, Baz
                        PS: Great music πŸ‘
                        • pmolsonP
                          pmolson
                          Thanks Baz You may be using a lot more initial sketchup scenes. My settings are very similar to yours, but I only end up with about 1800 - 2000 images. I start out usually with about 12 - 20 scenes.
                          • DanielD
                            Daniel
                            They look great, pmolson. The only thing that stuck out to me was in the second video there appeared to be some 2d realistic trees mixed in with the NPR trees. And then all the trees suddenly disappear partway through the video.
                            My avatar is an anachronism.
                            • pmolsonP
                              pmolson
                              Hi Daniel, Thanks for the comment.
                              good eye on the 2d trees. I was experimenting with those trees on that model because the client chose to use a little color on that model instead of our usual grey style.
                              I need to find some npr 2d trees.
                              These models get very heavy and become almost unworkable if I use all the 3d trees I would want. Even when I isolate groups of 3d trees & bushes not in a particular view and turn them off, the regen time in each scene can be time consuming. The combination of the wiggly line style I use with shadows and 3d trees & bushes becomes a bit of an animal.
                              I just upgraded my computer and it handles it better, but I still have to be selective about 3d tree & bush use.
                              The reason for the trees disappearing is simply time & money. It was time to be done so we went with a couple glamour shots and then went makeupless...so to speak.
                              p
                              • DanielD
                                Daniel
                                I feel your pain - I've been there before, trying to fill a model with enough entourage without overtaxing the system.
                                Have you looked on 3D Warehouse? Some guy in our office recently did a model with 2D trees he pulled from that site. And have you tried at any styles that include an NPR tree backdrop?
                                • pmolsonP
                                  pmolson
                                  Daniel
                                  I have tried the back drop idea, but it always feels...wrong I guess. It can work great for still shots though. The style i use was created specifically for this client and they are happy, so I would be wise to not fix what is not broke.
                                  I have looked around a bit for npr tres, but I need to try harder. Maybe this very minute!
                                  p
                                  • bazB
                                    baz
                                    @pmolson said:
                                    I have looked around a bit for npr tres, but I need to try harder. Maybe this very minute!p
                                    Have a look at 'TomsDesk" http://www.tomsdesk.moonfruit.com
                                    I used them extensively in my example
                                    • pbacotP
                                      I was just using Tom's shrubs today! Unfortunately he never came up with the "new" shrub bundle he shows a teaser for. I think he dropped making new products a long time ago. Those rees are heavy on the program if you use too many, but well-made, including layers so you can position without all the leaves turned on. They are good looking in SU output.
                                      • bazB
                                        baz
                                        Yeah, haven't seen him round the forum for a while either...
                                        • AdamBA
                                          AdamB
                                          Looking at your videos, they look to me to be 10fps - they're certainly not 30fps.
                                          Check your settings not just on exporting from SU but your video codec is set to 30fps also.
                                          Adam
                                          • pmolsonP
                                            pmolson
                                            Thanks for the Toms desk info.
                                            adam, I will look at the codec...here it is
                                            mp4-h264 1920X1080p 30
                                            frame rate 29.97
                                            I mess with the duration of the images in my video editor to get the movies to be the desired length of time. I wonder if that is where I am stumbling..?
                                            • 1 / 2
