    Round front edge of
    5 Posts 4 Posters 640 Views 4 Watching
      davesexcel
      ` prompts = ["length", "width","height"]
      defaults = [36.0,10.0,1.0]
      input = UI.inputbox prompts, defaults, "Tread."
      if input == false
      UI.messagebox("All Must Be Entered")
      else
      a,b,c=input
      UI.messagebox("Tread input accepted!, #{input}!")
      ent = Sketchup.active_model.entities
      face = ent.add_face [0,0,0], [a,0,0], [a,b,0], [0,b,0]
      #face.reverse!
      face.pushpull c`
      I am using the above code, how can I round the front edge of my drawing. for example Height is 1, then I would like the front to be rounded with 1" diameter.
      thanks.
      • K Offline
        ktkoh
        You will probly get better answers and but I would draw the end face wich would include the radius and push the length. I did this for my loose tenons. I used simple trig to calculate as many radius points needed. The built in radius would be more flexible but I never got the hang of it.
        Keith
        Ps. Send pm if interested in my code.
        • sdmitchS Offline
          sdmitch
          if input == false
          else
          a,b,c=input
          #face.reverse!
          face.pushpull c`
          thanks.
          One possibility
          if input == false
          else
          a,b,c=input
          ent.add_line [0,b,0],[0,0,0]
          ent.add_arc [0,0,c/2.0],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,6
          ent.add_line [0,0,c],[0,b,c]
          edg=ent.add_line [0,b,c],[0,b,0]
          edg.find_faces; face=edg.faces[0]
          #face = ent.add_face [0,0,0], [a,0,0], [a,b,0], [0,b,0]
          #face.reverse!
          face.pushpull -a
          http://sdmitch.blogspot.com/
          • G Offline
            Garry K
            You could use Fredo6 Round Over.
            I do this for curved stairs with radius corners.
            I use a polygon mesh and fill in all the surfaces.
            Tread after filling in
            Tread before filling in
              davesexcel
              Thanks a lot for the replies. The code actually draws it the way I would draw it manually.
              Thanks!
