    Paste In Place a Copy to Current (Active) Layer
    5 Posts 3 Posters 909 Views 3 Watching
    • JClementsJ Offline
      JClements
      I was wondering if someone would be willing to create a script that would Paste In Place a copy of a selection to the Current (Active) Layer.
      Pasting in place geometry over itself in order to put the copy onto a another layer can be fiddly.
      Regards, John
        DOD3R
        Yes please that would be great.
        I would like it even as a deafult beahvior of the sketch up to paste geometry on active layer.
        Or make a switch for it so we can make this feature work for every scenario.
        • sdmitchS Offline
          sdmitch
          It appears that Sketchup wont allow two entities to occupy the same location even if they are on separate levels. I think you would have to group them first. Something like this
          mod = Sketchup.active_model
          ent = mod.active_entities
          sel = mod.selection
          org = ent.add_group sel; org.name = 'org'; org.layer = 'Layer0'
          new = org.copy; new.name = 'new'; new.layer = mod.active_layer
          new.entities.each{|e| e.layer = mod.active_layer}
          http://sdmitch.blogspot.com/
            JClements
            [Update]
            see posting below
              JClements
              The attached will copy and paste in place a group or component to another layer.
              It will appear in the Edit menu as "Paste In Place Copy of Group/Component to Layer".
              Paste In Place A Copy.rb
              Select a group or component and run the script. You will then be asked to choose a layer to paste the copy. The current layer will be initially displayed in the list.
              Thanks Sdmitch.
              Here is a test file to experiment with (SU2015 format).
              paste in place a copy, test.skp
