    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 351.1k Views 53 Watching
    • cottyC
      cotty
      @jbgood said:
      Hope some one can help I have SU 14 pro and just downloaded SketchyPhysics 3.5.5 (October 25 2014) but there does not seem to be any way to install it help anyone please
      JBgood
      There are several ways to install plugins in 2014, which one did you choose?
      my SketchUp gallery
      • A
        Anton_S
        @jbgood said:
        JBgood
        You may also refer to this post, I'll add it part of main description:
        http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936%26amp;start=30#p540351
        • D
          deskpilot
          May I jump in on this thread gents. I've recently purchased a new pc,loaded SU2014Make and SP3.5.5.. Kept getting that annoying warning about a bad install so I went back a step and loaded an earlier version, 3.1. Now, full install seems OK but the plugin is permanently disabled. Try as I might, I can't get it to do anything but say it will be disabled next time I fire up my pc. Any answers please. If I have to go into DOS or similar, please explain all steps.
          • A
            Anton_S
            Hello,
            It would be nice if you provide me some more details.
            • What warning message do you get?
            • What operating system are you using?
              Regardless of that, I don't think SketchyPhysics 3.1 will work in SU2013 or above. Keeping it in the 2014 plugins folder is useless. I suggest you to go to C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins, and erase all sketchy physics versions from the folder. Then, download the SP3.5.5 if you hanven't so, and extract content into the plugins folder. It should look like this:
              *...\Plugins*
            • SketchyPhysics3
            • SketchyPhysics.rb
            Hope this helps or provide some details if you can't get it working.
            • D
              deskpilot
              OK, done as you suggested but now I'm back to:
              Loading error
              Error Loading File sketchyphysics.rb
              Error: #<LoadError: cannot load such file -- SketchyPhysics3/ClassExtensions.rb>
              C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in load' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in LoadSketchyPhysics3'
              C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:61:in doLoad' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:137:in <top (required)>'
              Would appreciate next step
              Cheers, Doug aka Deskpilot
              PS, running Windows 7 Home on a 64 bit systems
              • A
                Anton_S
                That file is from old sketchyphysics version. It seems you didn't delete sketchyphysics.rb from the plugins folder as i suggested in previous post.
                • D
                  deskpilot
                  Sorry to bother you again Anton but try as I might, I'm still not getting SP to work. All looks good when I view my files. All sub folder appear to be there but in SU, there's no sign off it.
                  Is this correct?
                  C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins\SketchyPhysics3
                  In the SP3 folders, there's every thing I would expect.
                  Where else should there be folders or files that I can check?
                  BTW, I completely uninstalled/deleted everything and started again with a fresh download.
                  • A
                    Anton_S
                    @deskpilot said:
                    Is this correct?
                    Ah, I see your problem. SketchUp 2014 has its plugins folder in different location. SU2014 and above have their plugins folder in AppData, while prior version have their plugins folder in Program Files. Delete the plugins folder you created in C:\Program Files (x86)\SketchUp\SketchUp 2014, and use the correct path, C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins.
                    The easy way to get to AppData is to write and send %appdata% in your windows explorer address bar, and from there you could navigate to your plugins folder.
                    The final path should look like this:
                    *C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins*
                    SketchyPhysics3
                    SketchyPhysics.rb
                    I'd suggest you to erase all the prior sketchy physics version if you installed any. You don't need them to get the latest version working.
                    Here is the similar post to consider if I didn't make it clear: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=59782#p544700
                    Hope you can get it working, I will add installation instructions to the main post.
                    • W
                      willeykj
                      I shared emails with Chris the other day and he and I both agree its time to get the original source code for the libraries out into the community. (Chris really did all the work and created SP, I just did the port to OS X).
                      Despite our best intentions, we will never pick up the threads and get SP going as fast as Anton and you (the rest of the passionate SP community) are doing.
                      What is the preferred method you'd like for getting the source code into the hands of the community?
                      For those that are confused by this - I'm not talking about the Ruby code. I'm referring to the C code in the extension libraries that hook the SP ruby code into the Newton physics library and other assorted Ruby C Extensions that access OS specific functionality and other libraries (like SDL, Midi support, etc...).
                      • D
                        deskpilot
                        Thankyou very much Anton, it's all there now. I'll play with it a bit later (only just got up). As you been discussing, this needs to put out there for the wider community.
                        • A
                          Anton_S
                          Very well!
                          I think GitHub is the best way to share source to the community.
                          • gillesG
                            gilles
                            Is there a way to make control panel pop up elsewhere than in the middle of the screen?
                            • BoxB
                              Could you look at changing the opening state of the toolbars.
                              If you have it loaded they will always open on startup whether you closed them last time or not.
                              @Gilles Might be different on the Mac, but I moved it aside and it now always opens where I moved it.
                              • gillesG
                                gilles
                                This does not work on my mac 😠
                                • R
                                  RTLMII
                                  Any Idea when a Sketchup 2015 X64 Sketchyphysics version will be available?
                                  • A
                                    Anton_S
                                    It won't be available until people owning C++ source of SketchyPhysics decide to release 64bit compatible libraries that are used by SketchyPhysics.
                                    • T
                                      TANER TAN
                                      Hello! Very useful plugin! We expect the SketchUp 2015 64-bit compatible version. Thanks.
                                      • N
                                        N Lindenthal
                                        404 Not Found
                                        (sketchucation.com)
                                        Please excuse me, if I did not lern my English very well.
                                        SketchyPhysics gives wings.
                                        Above is my sample file. My question is: How can I stabilize the joints so that they don't tremble so strong?
                                        Maybe someone can set the parameters in the pattern file or give little hints.
                                        Many greetings
                                        Norbert Lindenthal
                                        • A
                                          Anton_S
                                          It says I'm not authorized to download the file. Looks like you have to upload the attachment the other way, in the Upload attachment tab when you post a reply.
                                          Meanwhile, to reduce joint flexibility, both bodies the parent and child have to have an identical mass. That is easy to set.
                                          1. Select parent body, open control panel, and enable the scripted checkbox.
                                          2. In the scripted field write,
                                          onStart {
                                            this.setMass(1.0)
                                          1. Do same for the child body.
                                          You can change the 1.0 to any desired value. As long the values of parent and child bodies are not way off, the joint should remain strong.
                                          Here is the video demonstration:
                                          https://www.youtube.com/watch?v=qw2C9goxbNk%26amp;list=UUFRTk8PFA2D36yHxwYrulIw
                                          Move timestep to 1:20 for visual instruction on how to set identical mass.
                                          • A
                                            Anton_S
                                            According to Newton Dynamics, it's impossible to make newton joints 100% stiff. So, your model might end up in such situation. However, you can increase joint damp parameter to 100. It will reduce angular speed.
                                            Here is the fixed model:
                                            Verschraenkt.skp
                                            Edit: Sorry, I had to edit this like 5 times.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 7 / 11
