    Probem Using UI:WebDialog and Javascript
    6 Posts 4 Posters 903 Views 4 Watching
    • C
      curator
      Hi all,
      I have some problem here. I created the follwing minimal example as an HTML File:
      <script>
      function callJavaScript(i_Value)
      alert('hi')
      	var jsonString = '{ "foo"; 42, "bar"; 17 }';
      	var jsObject = JSON.parse( jsonString );
      	alert(jsObject["foo"])
      	var message = jsObject["foo"];
      	document.getElementById('output').innerHTML = message;
      alert(obj.count);
      </script>
      <html>
      	<body onload = "callJavaScript('Update')">
      		<h3 id="output"></h3>
      	</body>
      </html>
      Wenn opening in a browser, it start by welcoming with 'hi' and prompts 42 afterwards. That makes no sense, but works as expected. However, if I now use sketchup to display that html file, e.g., like this:
      p_File = Sketchup.find_support_file("DEMO.html","Plugins")
      			p_Dialog = UI;;WebDialog.new("DEMO")
      			p_Dialog .set_file(p_File )
      			p_SettingsDialog.show
      That does not work anymore. The Dialog opens and greetings 'hi' still works, but the JSON stuff doesn't work anymore.
      Can anyone provide any help?
      kinds regards,
      curator
      • D
        driven
        seems to work as set html...
        html = %Q(<script>
        alert('hi')
        alert(obj.count);
        </script>
        <html>
           </body>
        </html>)
                 p_Dialog.set_html(html)
                 RUBY_PLATFORM =~ /(darwin)/ ? p_Dialog.show_modal ; p_Dialog.show()
        I'm on a mac, hence the show_modal
        john
        • Dan RathbunD
          Dan Rathbun
          FYI, everything should be inside the <HTML> </HTML> tags.
          Read ThomThom's Lost Manual for WebDialogs and the alternative to body.onload that works better with SKetchUp.
          https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki
          EDIT: Sorry, just looked, it is not in there. But I know it is in many replies Thomas gave in this forum on the same topic. Determine the status of when the document is ready.
          I'm not here much anymore.
          • tt_suT
            tt_su
            Yes, I use jQuery's ready event exclusively as it takes care of all cross browser compatibility.
            Not sure why you are seeing differences between set_html and set_file, but cleaning up the HTML to valid syntax would be the first step. All bets are off if the markup isn't valid - browsers try to recover very differently.
            • tt_suT
              tt_su
              By the way, what OS?
              • C
                curator
                Thanks very much, cleaning up html did the job. If its still of intereset, i use windows 7.
                Haven't seen my HTML mistake, so thanks again,
                curator
