    Probem Using UI:WebDialog and Javascript
    6 Posts 4 Posters 751 Views 4 Watching
      curator
      Hi all,
      I have some problem here. I created the follwing minimal example as an HTML File:
      <script>
      function callJavaScript(i_Value)
      alert('hi')
      	var jsonString = '{ "foo"; 42, "bar"; 17 }';
      	var jsObject = JSON.parse( jsonString );
      	alert(jsObject["foo"])
      	var message = jsObject["foo"];
      	document.getElementById('output').innerHTML = message;
      alert(obj.count);
      </script>
      <html>
      	<body onload = "callJavaScript('Update')">
      		<h3 id="output"></h3>
      	</body>
      </html>
      Wenn opening in a browser, it start by welcoming with 'hi' and prompts 42 afterwards. That makes no sense, but works as expected. However, if I now use sketchup to display that html file, e.g., like this:
      p_File = Sketchup.find_support_file("DEMO.html","Plugins")
      			p_Dialog = UI;;WebDialog.new("DEMO")
      			p_Dialog .set_file(p_File )
      			p_SettingsDialog.show
      That does not work anymore. The Dialog opens and greetings 'hi' still works, but the JSON stuff doesn't work anymore.
      Can anyone provide any help?
      kinds regards,
      curator
        driven
        seems to work as set html...
        html = %Q(<script>
        alert('hi')
        alert(obj.count);
        </script>
        <html>
           </body>
        </html>)
                 p_Dialog.set_html(html)
                 RUBY_PLATFORM =~ /(darwin)/ ? p_Dialog.show_modal ; p_Dialog.show()
        I'm on a mac, hence the show_modal
        • Dan RathbunD Offline
          Dan Rathbun
          FYI, everything should be inside the <HTML> </HTML> tags.
          Read ThomThom's Lost Manual for WebDialogs and the alternative to body.onload that works better with SKetchUp.
          https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki
          EDIT: Sorry, just looked, it is not in there. But I know it is in many replies Thomas gave in this forum on the same topic. Determine the status of when the document is ready.
          I'm not here much anymore.
          • tt_suT Offline
            tt_su
            Yes, I use jQuery's ready event exclusively as it takes care of all cross browser compatibility.
            Not sure why you are seeing differences between set_html and set_file, but cleaning up the HTML to valid syntax would be the first step. All bets are off if the markup isn't valid - browsers try to recover very differently.
            • tt_suT Offline
              tt_su
              By the way, what OS?
                curator
                Thanks very much, cleaning up html did the job. If its still of intereset, i use windows 7.
                Haven't seen my HTML mistake, so thanks again,
                curator
