    Testing Ruby VALUES in C-extension.
    69 Posts 6 Posters 5.1k Views 6 Watching
    • jolranJ Offline
      jolran
      I'm using the Hello world C++-extension example and playing around with it, trying to get a grip of things..
      Thank you very much for putting that, up by the way πŸ‘
      This is probably a very basic noob question. But can we compare Ruby objects for equality when they are in C/C++ ? Before converting them to structs or whatever..
      Or maybe do other tests.
      (GC-issue, and altering Ruby VALUES set aside for a moment)
      I was under the impression C dident have a clue what VALUES where..
      Actually I'm testing Sketchup Point3d objects, so I presume it's not entirely correct to say they are real Ruby objects.
      I made a simple test case that seams to give me the correct answer:
      It's just added to the Hello world example..
      //C++
      VALUE test_2_objects(VALUE self, VALUE obj1, VALUE obj2) {
      	if ( obj1 == obj2 )
      		return Qtrue;
      	else
      		return Qfalse;
      Then a simple call to C
      def self.test2objs()
      		pt1 = Geom;;Point3d.new(0,1,3)
      		pt2 = Geom;;Point3d.new(66,10.55,3)
      		r1 = EC_CEXT;;test_2_objects(pt1, pt1)
      		puts "2 Equal points. Are equal ? #{r1}"
      		r2 = EC_CEXT;;test_2_objects(pt1, pt2)
      		puts "2 Not equal points. Are equal ? #{r2}"
      Which then puts:
      2 Equal points. Are equal ? true
      2 Not equal points. Are equal ? false
      Can't be that simple ? Really ? πŸ˜„
      Ive seen conversion from Points to struct. But I was thinking of avoiding that step unless needed to compare x,y,z values or altering the values.
      Testing for ex a vector3d against Point3d does not give an error BTW..
      • SkalpS Offline
        Skalp
        These 2 books as a good part about C-extensions:
        http://media.pragprog.com/titles/ruby3/ext_ruby.pdf
        302 Moved
        (books.google.be)
        Skalp
        http://www.skalp4sketchup.com
        • jolranJ Offline
          jolran
          Thanks!
          The first 1 I have read(apperarently not very thourough πŸ˜„ ). The second one looks interesting, will try to get my hands on that.
          In pragmatic P they say ruby VALUES in C with a few execptions simply are pointers to objects/memory.
          edit: Book nr 2. Very interesting read πŸ‘ There's a lot to digest. I have a lot to learn. Sigh.. Not enough daylight..
          • tt_suT Offline
            tt_su
            //C++
               if ( obj1 == obj2 )
                  return Qtrue;
               else
                  return Qfalse;
            This won't work for VALUE types. A VALUE is a typedef of long. And it's working more like a pointer. So you would be comparing the address of the data in the code you have.
            To compare using the Ruby logic of comparing you need to invoke the Ruby methods to do so.
            I cannot recall if the Ruby C API has a method to invoke the == operator or if you need to call it your self. But that's what you need to do, for the Point3d class it will make a tolerance based comparison of the two points.
            • tt_suT Offline
              tt_su
              I just found you have rb_eql and rb_equal - these are the ones you want to use.
              • tt_suT Offline
                tt_su
                Hmm... might want to do some testing to see how it's implemented:
                http://stackoverflow.com/a/7157051/486990
                • tt_suT Offline
                  tt_su
                  http://rxr.whitequark.org/mri/source/object.c#100
                  • tt_suT Offline
                    tt_su
                    As far as I can tell you must use rb_funcall to invoke the == operator of the Geom::Point3d class.
                    • jolranJ Offline
                      jolran
                      Hi Thomthom.
                      I suspected I was comparing adresses, which deceivingly gave the correct answer in this particular case. But will fail (?) if comparing to equal objects from different address.
                      I will stick to that.
                      Does it slow down the code much invoking Ruby methods in C ?
                      I have that impression from reading topics in here..
                      It must be complicated to avoid doing so in many cases.
                      The main reason for thsi was that I was planning on building a hash.index(object) function
                      in C. It's rather slow in Ruby.
                      (Or any function that will get the key in a Hash from a value).
                      Anyway, thanks a lot for the help! I will read the links carefully now.
                      • tt_suT Offline
                        tt_su
                        Don't think there is much difference calling a method from a Ruby script or doing the same call from C. Interacting with the Ruby system is slow.
                        I found that to get benefit from the speed improvements you need to do sufficiently outside of Ruby land.
                        Example, the soft-selection calculation in Vertex Tools was very slow. Simply dropping into Ruby C and doing the same calls there made no real difference. What made a difference was that I converted the array of points into C structures and then made all my comparisons and calculations, then converted the result back to Ruby.
                        Are you trying to use 3d points as hash? And you want it to make two point of similar position within tolerance be treated as the same object?
                        • jolranJ Offline
                          jolran
                          That is very good to know!
                          I have looked a lot at your C codes, (from Bitbucket). I was wondering about that part.
                          From an untrained eye it looks rather cumbersome to convert to struct and then back again, isent there a huge cost in doing so ?
                          What you are saying it's the opposite ? I wouldent mind doing that. It would be a consistent way of dealing with points.
                          Needless to say, I don't really understand how things work in C-extensions yet..
                          Hmm, No. I use a Hash as container for points. like this { 0 => pt, 1 => pt etc }
                          This Hash is then compared/used against arrays of indexes(integers) referring to this Hash.
                          So I need to lookup the key(index) from value(pt) often when dealing with these arrays in different methods.
                          The spontanious reaction would be to use an Array instead of Hash for this, but after some "interesting" benchmarks when using array.index(object) I decided to use a Hash. πŸ˜„
                          I havent tried a set yet though, might be better candidate..
                          I don't know which one is simpler to work with in C.
                          • tt_suT Offline
                            tt_su
                            The soft-selection calculation needs to compare each point against every other point, so it's O(N2)!! :s Getting the for each inner iteration, getting the VALUE and then getting the X, Y and Z values and converting them to native values every time leads to a big a big performance hit due to the overhead of invoking the Ruby interpreter.
                            The "overhead" of doing a pre and post pass to convert the set of 3d points to native C structs is insignificant in comparison. Consider this: I access the Ruby values exactly once! No more than I need to.
                            That yielded around a 100 times performance increase in my case which was fast enough. If I had needed more improvement I might have done so by using a different data structure to sort my points and doing more efficient lookups - like a K-tree or Oct-tree. But so far it's doing fast enough and there is not need to optimize before it's an issue. (Which is very important to remember by the way!)
                            And when you optimize, make sure you have done your timing and profiling so you actually know where the bottleneck is. And time your changes so you know you are getting positive results. Occasionally rewrites leads to regressions due to unexpected circumstances.
                            I can only give generic tip based on my own experience, but ultimately you cannot rely on that to apply to your scenario. Test and measure.
                            I'm not sure you can do that much faster than a hash look up, even Ruby hashes - they are pretty fast for what it's worth. They have a O(1) performance. Maybe I'm not seeing the whole picture of what you are doing, but if you try to simply make a faster C implementation of a hash structure I have my doubts.
                            That's because arrays are O(n) - in order to look up an item the whole array must be iterated until it find a match. Hashes are constant lookups O(1). I use Hashes a lot in Ruby when I need performance, often they are enough to give me the speed I need.
                            A set wraps a hash - so it should have about the same performance. The difference with a Set is that you only have unique values, while a hash have key-value pairs.
                            Note that the Ruby StdLib Set is much faster than the old Sketchup::Set class.
                            If you are diving into Ruby C Extensions I would recommend using our GitHub projects which is in fact a C++ Extension. C++ is much nicer to work with, especially C++11. I spend a lot of time writing pure C extensions early on because Ruby was just plain old C. And I though C++ was even harder - boy way I wrong. Since you are familiar with Ruby and the objective world you will find yourself more familiar with C++ where you can have classes. Constructors and destructor are your friend in C++.
                            In my latest project I've begun creating a C++ wrapper over the C++ API so in fact a lot of my C++ code looks like Ruby. πŸ˜„ I might take a chunk of that and make it open source eventually.
                            For what you are doing right now you might want to look at taking bigger chunks of calculations and doing them in C/C++. If you find that you constantly have to visit Ruby land you might find there is little to gain. Especially if you need to call SketchUp's API as all the methods there are implemented in C++ and the only overhead is the Ruby function call.
                            If you have some more details on your specific issue I might be able to give more concrete advice.
                            Btw, if you are unfamiliar with the Big O Notation, here's a couple of links:
                            http://rob-bell.net/2009/06/a-beginners-guide-to-big-o-notation/
                            http://bigocheatsheet.com/
                              Anton_S
                              Interesting topic guys, keep it up πŸ‘
                              Something tells me SU2015 could have support for plugins in C++. Would be awesome.
                                Anton_S
                                There is a topic that compares the speed of programming languages to πŸ˜„ http://www.unlimitednovelty.com/2012/06/ruby-is-faster-than-python-php-and-perl.html
                                Unfortunately Ruby is ~50 times slower than C++. I think no one would disagree with SketchUp API in C++ and plugins that consisting of cpp files.
                                • jolranJ Offline
                                  jolran
                                  +1
                                  • jolranJ Offline
                                    jolran
                                    Awesome answer man! Very rich post πŸ‘
                                    I absorb your recommendations, comments are not necessary πŸ˜„
                                    (nice links btw, now I finally understand Log(n)!).
                                    Regarding the Hash lookups. Yes they are fast if using the key. But if looking for the key from a value it's a bit worse. And in my case I see no way around avoiding that lookup.
                                    I'm doing vertex indexing.
                                    http://www.opengl-tutorial.org/intermediate-tutorials/tutorial-9-vbo-indexing/
                                    Where I sometimes have to insert new uniq points, and get the index from a point when sorting the indexed arrays by some algoritm.
                                    I am using the C++ hello_world tutorial as staring point, and expanding on that.
                                    How do you debugg BTW ? It's a bit enoying haiving to quit Sketchup when pasting in .so files. Windows don't allow me to copy and paste over so files that are in use by Sketchup 😞 One cannot unload dll's, right ?
                                    There is a debug and release modes(I'm in VS 2010 Ultimate BTW) but I can't launch debugger with SU8 and debug 1.8.
                                    The original project seams to be linked to Sketchup 2013(which I don't have) so I tried to link to SU8.exe to no avail.
                                    What I've seen the recommendation is to use VS 2010 (if windows). Unfortunately VS 2010 lack some of the nice C++11 features, but I guess we can live with that.
                                    A bit difficult to follow some newer C++ tutorials though.
                                    Yeah, but scary subject. I followed some tutorials here:
                                    http://www.microsoftvirtualacademy.com/Content/ViewContent.aspx?et=5730%26amp;m=5723%26amp;ct=23224
                                    recommending RAII with uniq pointers inside try and catch block. So in our case one could use that to ensure longjumps to Ruby if an Exeption ?
                                    (Way over my head at this stage, but interesting.)
                                    I havent found much info about dealing with objects in C++ and memory handling in C-extensions yet.
                                    I presume the Alloc_n -> xfree trick does not apply in this case ?
                                    Or maybe it's the same in C++ if using a struct and not Class.
                                    A struct must be perfect choice for Point3d in any case ?
                                    Once again. Thanks a lot for that post. Very useful.
                                    • tt_suT Offline
                                      tt_su
                                      Why are you looking for a key by value? Sounds inverted.
                                      Are all your values uniq?
                                      You could keep a second hash with reversed pairs... but then again, it sounds odd and I don't know the full scope of your task. (And I haven't finished reading the rest of your post. :p)
                                      • jolranJ Offline
                                        jolran
                                        Yeah πŸ˜„ I may very well have a design-flaw on my hands..
                                        But it is a well-used pattern.
                                        I'm using a Hash with uniq points. And then building different geometries from those points for rendering Open_Gl Triangles and edges.
                                        Normally the ordering of points for face-triangles VS face-edges are different.
                                        So one ends up with 2 arrays of points. 1 for GL_Triangles , 2 for GL_edges.
                                        NOW, Instead of having 3 Containers filled with points. You have only 1 HASH. And 2 Arrays of integers that act as lookups-key to the Hash.
                                        In terms of space this is more lightweight. But The greatest advantage is when for ex Transforming all that geometry. I only have to transform the uniq points.
                                        Using Polygonmesh for this would be better, but one cannot update or purge a polygonmesh.
                                        And I would need to build the 2 arrays anyway, so I have my own class for this purpose.
                                        There are some mechanics for sorting and then I have to lookup the key from a value.
                                        Hope that makes the subject clearer..
                                        • tt_suT Offline
                                          tt_su
                                          It is in fact set up to SU2014. When you click run it should launch SketchUp 2014 and a supplementary RB script should load the c extension for you.
                                          Indeed. I have VS2013. You can load the project just fine, but if you want to use it as-as you must decline to upgrade it.
                                          If you do choose to upgrade you must modify the Ruby headers as they are not configured to VS2013. That's what I do for my projects now because I like C++11 so much with it's lambdas, smart pointers, ranged for loops and other goodnesses. πŸ˜„
                                          No, you cannot catch Ruby's long jumping error-raising. However, in my testing, if Ruby long jumps out of a function destructors are called - which is a good thing. With C++11 when you have smart pointers that makes memory management a breeze. But if you use plain ol' naked pointers you must take more care. You must either use rb_rescue or re_ensure (which are horrible constructs) or wrap all your memory allocation into classes (which is a good thing to do anyway.)
                                          I recently made a wrapper that converts C++ exceptions into Ruby errors, so I can throw my own custom errors around in my C++ code and have the Ruby layer catch that. Pattern seems to be working quite well, keeps error handling code clean.
                                          From what I've read on best practices people recommend using classes over structs - as a general rule. The reason is that you make accessors to the data members which ensures that you don't expose them directly. Why is that good? Because if you later need to change one of the member to be calculated on demand you just change the accessor method and not every piece of code that points to it.
                                          Alloc_n and xfree are C ways of dealing with memory - which is might kill small bunnies. With C++ you don't need to deal with that.
                                          Exception: if you need to wrap a C data structure in Ruby you need to use xfree to clean up the memory when the Ruby garbage collector collect the object.
                                          Happy to help! I'm glad more people are looking into more advanced ways of creating extensions. πŸ˜„
                                          • tt_suT Offline
                                            tt_su
                                            I'd try to wrap that whole calculation in a C extension. C++ extension that is. πŸ˜‰
                                            I'm dealing with this right now for my subdivision extension. Working on live update of the mesh when you adjust the creasing. (And any other part of the mesh.) Lots of things to keep in sync - lots of ways to get it wrong.
                                            • 4 / 4
