    Ruby 2.0.0 Threads in SU | how to keep a subthread running?
    20 Posts 6 Posters 2.6k Views 6 Watching
      SR20VET
      Hi SU,
      I'm testing some multithreading in Ruby.
      It seems like the main thread goes into a sleep state when the user is not interacting with Sketchup and/or no script is executing.
      Take a look at this:
      seconds = 0;
      counter_thread = Thread.start do
      	loop do
      		seconds += 1;
      		sleep(1);
      	end#do
      end#do
      If I just leave the ruby console for what it is after entering this script and don't interact with SU for some seconds, this new thread doesn't run. If I type
      seconds
      in the console it just says, 1 or 2. However, if I do react with SU, just move the mouse, change the camera position, ... the thread does run and the seconds gets updated.
      Spawning a timer on the main thread also keeps the message pump running, but not at full "speed". After some time the seconds are incorrect.
      I was wondering if there is some way to keep a subthread running, without the need to interact with SU?
        Anton_S
        I can't reproduce what your experiencing: Entering this into console, closing console, wait a little without motion, open console, write seconds, but I get like 15, or 20 seconds which is about right.
        Can you try this code in console? I know its same code, but it could make it different.
        seconds = 0; Thread.new(){ while true; seconds += 1; sleep(1) end }
        I am using Windows, FYI
          SR20VET
          That's funny. If I close the console it does count indeed! But, when I press ENTER after entering the script, sit and wait for 15 seconds and then enter seconds, it does return 1 - 2
          It look like the SU window has to have focus or a mouse hover.
            Anton_S
            Hmm, I tried your technique, but I still get like a descent time.
            Aha! When I enter this in console and unfocus the window the thread stops running, but when I refocus, it starts running again. I think that's how Windows work...
              SR20VET
              Hmm.
                Anton_S
                I was wrong about automatic Windows Thread Suspension. All you need to due is call thread.run or thread.wakeup after creating the thread:
                seconds = 0; t = Thread.new(){ while true; seconds += 1; sleep(1) end }; t.run
                It seems to work even if I suspend/deactivate the window. Can you verify?
                  SR20VET
                  I have the same issues with your latest code. When I simply enter the code, press ENTER, wait a couble of seconds and then type seconds, still not a proper amount of seconds.
                  Although it seems that, while I'm writing this post, the thread is running... while at the start of the thread I entered "seconds" a couple of times, still with about 10 seconds.
                  I'll try: seconds = 0; t = Thread.new(){ while true; seconds += 1; sleep(1) end }; t.run
                  and puts "seconds: #{seconds} and time: #{Time.now}"; a few times. Here is the result in the console, it does run, but not perfect:
                  #<Thread:0x92a18d8 run>
                  seconds: 1 and time: 2014-08-14 23:39:00 +0200
                  nil
                  seconds: 7 and time: 2014-08-14 23:39:07 +0200
                  nil
                  seconds: 14 and time: 2014-08-14 23:39:15 +0200
                  nil
                  seconds: 25 and time: 2014-08-14 23:39:28 +0200
                  nil
                  seconds: 34 and time: 2014-08-14 23:39:39 +0200
                  nil
                  seconds: 43 and time: 2014-08-14 23:39:50 +0200
                  nil
                  • tt_suT Offline
                    tt_su
                    Yes, we have observed this. We're not sure why as Ruby claims native threads in 2.0 as oppose to the "green" threads in 1.8 - but yet something is amiss. Might be related to the Ruby interpreter running as embedded in SketchUp - which Ruby isn't really designed to. If you run standalone you will probably find it works fine.
                    • tt_suT Offline
                      tt_su
                      Btw, when sharing variables between threads you probably want to use Mutex. Not that it solves this issue though.
                        SR20VET
                        Ok tt_su, I might have to go the hard way then, and use native threads in a c++ extension.
                        • tt_suT Offline
                          tt_su
                          As things stand right now that would be the route to go.
                          We have a GitHub repo with the Ruby libs we use in SketchUp along with Visual Studio and Xcode projects set up: https://github.com/SketchUp/ruby-c-extension-examples
                            slbaumgartner
                            According to Programming Ruby 1.9 and 2.0 section 12.2, Ruby 1.9 and 2.0 encountered trouble with numerous existing libraries that were not thread-safe. "So, Ruby compromises: it uses native operating system threads but operates only a single thread at a time." That is very likely what you are seeing.
                            • tt_suT Offline
                              tt_su
                              So much for "multi-threading"... sigh
                              Still, the worker threads appear to act differently under standalone Ruby vs SketchUp embedded Ruby. So we are suffering from some side effect of how Ruby deals with its threads.
                              • Dan RathbunD Offline
                                Dan Rathbun
                                What about Ruby 2.1 ?
                                I'm not here much anymore.
                                  Anton_S
                                  Here are Ruby 2.1 release notes : https://github.com/ruby/ruby/blob/v2_1_0/NEWS
                                  I haven't found anything with threads though.
                                    SR20VET
                                    To make sure the subthread is running, we have to put the main thread in a sleep state.
                                    This is because Ruby does switch to another thread (if existing) when a thread goes into a sleep state.
                                    Now, is there a way to automatically put the main thread in a sleep state when the user is not interacting with SU? Once the user starts to interact (mouse movement, click, ...) the sleep state should be interrupted.
                                    I'm not aware of such an event in SU.
                                    For now this:
                                    message_pump = UI.start_timer(0.1, true) do
                                    	sleep(0.1)
                                    does help a bit, but ofcourse, this drastically affects SU performance. Even sleeping for 0.01 seconds does..
                                    • tt_suT Offline
                                      tt_su
                                      I wouldn't go the route of Ruby threads for now. If you really need it then use native threads in C extension.
                                      One scenario where it might be used is where you do multiple calculations in parallel and don't mind locking the main thread. You can then start your worker threads and join them with the main one. But other than that I would not rely on Ruby threads due to the current state of them.
                                        SR20VET
                                        Yep, I've taken the native threads path. Got the thread running, got even an http server running in that thread. But now, GIL is killing me. Can't call ruby from that second native thread...
                                        • tt_suT Offline
                                          tt_su
                                          Yea, that's another limitation. You can do calculations and such in other threads. But Ruby calls must be done some the main thread.
                                          • icehuliI Offline
                                            icehuli
                                            May I ask what exactly you are trying to do? I think you can call ruby from that second native thread.
                                            One important point is that the ruby function needs to be involved in the ruby thread, i.e. the SU thread. So in the c-extension there should be two threads, one is the same SU thread, the other is your second native thread. All ruby codes need to run within the SU thread.
