    SecureRandom slow
    10 Posts 4 Posters 1.1k Views 4 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      Hi guys,
      On SU 2014, I require 'securerandom.rb', then use SecureRandom.uuid.
      But for whatever reason, the first uuid takes several seconds to be generated. After that, it's instantaneous.
      Any idea why?
      • Dan RathbunD
        Dan Rathbun
        IF you have the CHM Ruby dictionary (comes in the "doc" folder of a system Ruby install,) you can click on the methods, and a code box will appear. Often this code is in C, but in this case, they are pure Ruby.
        SecureRandom::uuid calls SecureRandom::random_bytes
        # File lib/securerandom.rb, line 247
        def self.uuid
          ary = self.random_bytes(16).unpack("NnnnnN")
          ary[2] = (ary[2] & 0x0fff) | 0x4000
          ary[3] = (ary[3] & 0x3fff) | 0x8000
          "%08x-%04x-%04x-%04x-%04x%08x" % ary
        SecureRandom::random_bytes has several platform dependent conditional statements (I'll call them parts,) that execute one time setup code, then the else clause thereafter.
        The part that executes on Windows, you see must load "Win32API.rb" which conditionally loads other libraries.
        THEN, it sets up the Win API call object referenced by a instance var in SecureRandom, that is then used thereafter.
        The first part is used IF OpenSSL is loaded, the second part used by Mac/UNIX-like OSes.)
        The third partof SecureRandom::random_bytes that is used by Windows:
          if !defined?(@has_win32)
            begin
              require 'Win32API'
              crypt_acquire_context = Win32API.new("advapi32", "CryptAcquireContext", 'PPPII', 'L')
              @crypt_gen_random = Win32API.new("advapi32", "CryptGenRandom", 'VIP', 'L')
              hProvStr = " " * DL;;SIZEOF_VOIDP
              prov_rsa_full = 1
              crypt_verifycontext = 0xF0000000
              if crypt_acquire_context.call(hProvStr, nil, nil, prov_rsa_full, crypt_verifycontext) == 0
                raise SystemCallError, "CryptAcquireContext failed; #{lastWin32ErrorMessage}"
              type = DL;;SIZEOF_VOIDP == DL;;SIZEOF_LONG_LONG ? 'q' ; 'l'
              @hProv, = hProvStr.unpack(type)
              @has_win32 = true
            rescue LoadError
              @has_win32 = false
          if @has_win32
            bytes = " ".force_encoding("ASCII-8BIT") * n
            if @crypt_gen_random.call(@hProv, bytes.size, bytes) == 0
              raise SystemCallError, "CryptGenRandom failed; #{lastWin32ErrorMessage}"
            return bytes
        So once @has_win32 is defined, only the last small if statement is executed thereafter.
        I'm not here much anymore.
        • A
          Aerilius
          Could it be initialization?
          Click the source: http://ruby-doc.org/stdlib-2.0.0/libdoc/securerandom/rdoc/SecureRandom.html#method-c-random_bytes
          If you run it on Windows, it runs the first time also the if !defined?(@has_win32) block, later only the if @has_win32 block.
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Thanks guys.
            Ok so this is normal, my only option is to generate an uuid when the script loads and be done with it? (But it slows down SU's startup)
            • tt_suT
              tt_su
              What do you need the UID for? Do you need this particular implementation?
              • jiminy-billy-bobJ
                jiminy-billy-bob
                I need it for keeping track of component definitions throughout sessions.
                It would be easier if definitions had a persistent GUID (Why does the current one change when the definition changes? It's useless).
                In fact, all entities should have persistent GUIDs like groups and instances in 2014.
                • Dan RathbunD
                  Dan Rathbun
                  Why can't you save the defintion's guid into an attribute dictionary when it is first loaded (or created,) and thereafter let the API's change as it wants.
                  You simply use the original saved in the attribute.
                  • tt_suT
                    tt_su
                    Then if I was you I would find a different GUID generator that doesn't have the overhead. This one seems to be aimed at security, not just a GUID. Often hash generator (which this looks like) make a point out of being slow to make cracking harder and more expensive.
                    You just need something random enough. Using the hash of the component name might be good enough for your use. Current definition name and time should give you a different hash per component name per object.
                    id = "#{definition.name}#{Time.now}".hash
                    • tt_suT
                      tt_su
                      That can also work. πŸ‘
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Yeah I was looking at something like that. But Dan's solution is simpler and seems so obvious! πŸ˜„
                        smack on the forehead
