    Override the alt-key in a class ??
    3 Posts 3 Posters 434 Views 3 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      within my own class (tool) i use shift, ctrl and alt for alternative mouse functions.
      is it possible to override the native alt-function (menu-hi-lite) temporarily within a tool
      and set it back , when the tool is finished?
      i canot find any topic about this ....
      thanx
      stan
        Aerilius
        The %(#000000)[alt] key is often operating-system-reserved, and provides functions. If applications stay in their own field, there shouldn't be conflicts (or confusion of users).
        There are no special API methods for enabling/disabling. Some API methods can be used for to override default behaviour (inside the application), like onMButtonDown (default: orbit), onRButtonDown (default: application context menu).
        But have you tried pressing %(#000000)[alt]+ %(#000000)[altgr] ?
        A good alternative to overloading a tool with multiple modes is to just make several tools, and intuitive icons that make it easy to switch.
        • fredo6F Offline
          fredo6
          This is possible for ALT.
          You need to return true in the onKeyUp method for the case of key == ALT_MODIFIER_KEY.
          Actually, returning true seems to prevent bubbling. This is also a way to prevent characters to go to the VCB
          Fredo
