    Ruby: 3d align components
    5 Posts 3 Posters 591 Views 3 Watching
    • K
      kaas
      I'm trying to make a plugin that array-copies components along a line in a chosen plane. It could be used to assist in filling sections with real line hatches. See image:
      1. some custom components, axis at each bottom left corner.
      2. choose component from list
        3a pick starting point, 3b pick end point, 3c pick point to set plane of component (and maybe later for scaling some components to fit between parallel lines)
      I'm no smart coder at all so have used quite some bits from TIG's mirror.rb. It works..a bit.. but with several vectors the rotation goes totally wrong (for instance 3abc in the middle). I hope someone can help me out a bit and point me into the right direction.
      def drawArray
         @bbox = @comp_copy.bounds #bounding box of chosen component
         @v1= @pos1.vector_to (@pos2) # vector between first and second picked point
         @copies = (@v1.length / @bbox.width).ceil # set number of copies
         @nv1 = @v1.length = @bbox.width #set spacing on vector = width of component
         @baseVector = Geom;;Vector3d.new 1,0,0 #base vector of component
         @baseNormal = Geom;;Vector3d.new 0,0,1 #base normal of component
         @deltaVect = (@baseVector.angle_between @v1).radians	#angle between base component and chosen path
         @plane = Geom.fit_plane_to_points(@ip1.position, @ip2.position, @ip3.position)
         @planeNormal = Geom;;Vector3d.new(@plane[0], @plane[1], @plane[2])
         @deltaNorm = (@baseNormal.angle_between @planeNormal).radians #angle between normal of component and normal of the 3 picked points
         @first=true
         while @copies > 0
         if @first
            @translation = Geom;;Transformation.new(@pos1)
            @rotV = Geom;;Transformation.rotation(@pos1,@planeNormal,@deltaVect.degrees)
            @rotN = Geom;;Transformation.rotation(@pos1,@v1,@deltaNorm.degrees)
         else
            @v1.length = @bbox.width*@copies
            @translation = Geom;;Transformation.new(@pos1 + @v1)
            @rotV = Geom;;Transformation.rotation(@pos1+@v1,@planeNormal,@deltaVect.degrees)
            @rotN = Geom;;Transformation.rotation(@pos1+@v1,@v1,@deltaNorm.degrees)
         @componentinstance = @entities.add_instance(@comp_copy, @translation)
         @componentinstance.transform! (@rotV)
         @componentinstance.transform! (@rotN)
         @copies -= 1
         @first=false
      @state=0
      • jolranJ
        jolran
        Do you want to make the plugin yourself or do you just need the functionality for you own use ?
        I have code for hatching faces with components that hasent made it into Hatchfaces yet..
        You can pm me if you like..
        • sdmitchS
          sdmitch
          If you are willing to post or pm me a sample model and the plugin, I will be glad to see what if anything I can do with it.
          Otherwise I would use Geom::Transformation.axes.
          http://sdmitch.blogspot.com/
          • K
            kaas
            Hi Sdmitch, thanks for your offer. Jolran and I are already pm-ing about a solution so I think it will be already resolved.
            Max
            • sdmitchS
              sdmitch
              Max
              Great, but the offer is still good.
