    SU Podium Authorization Certificate revoked by Apple (!)
    4 Posts 2 Posters 510 Views 2 Watching
      scurnyn
      auth revoked screenshot
      Discovered this today attempting to install SU Podium on a new machine (OSX 10.9.3):
      -Both SU8 and 2014 Podium *.pkg files are blocked
      -Security set to allow Apps downloaded from anywhere
      -SU Podium's workaround does not work: http://www.suplugins.com/mtlion.php
      The revoked certificate may be related to the shutdown bugsplat issues discussed here: http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57201
      We rely on Podium as a part of our production workflow, so this is a big deal for us.
      FYI - By process of elimination we had also recently discovered that the Podium plugin is directly correlated with severe stability issues in SU 8 & 2014, rendering SU unusable (bugsplat every few minutes, bugsplat at every shutdown). Our plan of action for moving forward with Podium was to keep two installations of SU on each machine (SU2014 for modeling and SU8 with Podium rendering only).
      Would love to hear that there is a simple solution or that I'm doing something wrong. Thanks to everyone in advance.
      Cheers
      • olisheaO Offline
        olishea
        Please can you post this on the SU podium forum for a quick response.
        oli
          scurnyn
          Thanks, Oli. Just posted this over there as well:
          http://supodiumforum.websitetoolbox.com/post/su-podium-authorization-certificate-revoked-by-apple-6977095?pid=1283464318#post1283464318
          -Shane
          • olisheaO Offline
            olishea
            Looks like Dave has already replied to you.
            oli
