FOR 3D RENDERING
i want to assemble the following specs for 3d rendering
i just want to have an idea if the specs are compatiblecomment, suggestion please... thank you
Processor................Intel i7-4790 4 - 4.40 ghz. 4-core
MoBo......................Asus H97M-E
Video Card...............ASUS GTX750 OC 1GB GDDR5
Memory...................Kingstone 8GB 1600mhz
Primary Hard Disk......samsung 840 evo 120gb
Storage Hard Disk.....1 TB Seagate (7200 rpm)
Power Supply...........cooler master g550m semi modula
Chassis..................Coolermaster n300
I suggest you change GPU with this one http://www.legitreviews.com/gigabyte-geforce-gtx-760-4gb-video-card-review-2gb-4gb_129062, so you can use Thea Presto render engine inside SketchUP.
You will thank me later
For rendering, GTX 760 4GB sounds a good deal, but I'd probably look on a model that exhaust heat outside the case (more closed heat sink). For me it looks like this card may exhaust most heat inside the case. As all parts of system must stay cool, there is a risk that heat inside the case jumps too high. Maybe PSU will then get too warm air and it's fan will spin up... in a worst case PSU's performance will drop and you get odd system issues.
With your input, this post could be even better ๐
Register LoginAdvertisement
