    FOR 3D RENDERING
    3 Posts 3 Posters 1.3k Views 3 Watching
    • myren8tM Offline
      myren8t
      i want to assemble the following specs for 3d rendering
      i just want to have an idea if the specs are compatible
      comment, suggestion please... thank you
      Processor................Intel i7-4790 4 - 4.40 ghz. 4-core
      MoBo......................Asus H97M-E
      Video Card...............ASUS GTX750 OC 1GB GDDR5
      Memory...................Kingstone 8GB 1600mhz
      Primary Hard Disk......samsung 840 evo 120gb
      Storage Hard Disk.....1 TB Seagate (7200 rpm)
      Power Supply...........cooler master g550m semi modula
      Chassis..................Coolermaster n300
      ๐Ÿ˜„
      • srxS Offline
        srx
        I suggest you change GPU with this one http://www.legitreviews.com/gigabyte-geforce-gtx-760-4gb-video-card-review-2gb-4gb_129062, so you can use Thea Presto render engine inside SketchUP.
        You will thank me later ๐Ÿ˜„
        www.saurus.rs
        • N Offline
          notareal
          For rendering, GTX 760 4GB sounds a good deal, but I'd probably look on a model that exhaust heat outside the case (more closed heat sink). For me it looks like this card may exhaust most heat inside the case. As all parts of system must stay cool, there is a risk that heat inside the case jumps too high. Maybe PSU will then get too warm air and it's fan will spin up... in a worst case PSU's performance will drop and you get odd system issues.
