    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Choral Rehearsal Space
    3 Posts 2 Posters 1.6k Views 2 Watching
      tktechie
      Here's renders from a project I've been working with recently. The space is meant for choral and small instrumental assemblies. The lens angle in one of the shots is much wider than I'd anticipated. I've made no post production edits, other than the text at the bottom left.
      Disclaimer: I didn't design this room; I made a model and rendered what was on the CDs.
      https://lh3.googleusercontent.com/-584SFDAexHw/U7MdtL4ZsTI/AAAAAAAAAhw/ilAHUz1jg4w/w800-h450-no/Bailey+Hall+RenderSet+Prod+Scene6.png
      https://lh5.googleusercontent.com/-0qHOlvaxLOc/U7MdwLyFXTI/AAAAAAAAAh4/NRcGX6Ah5rQ/w958-h539-no/Bailey+Hall+RenderSet+Prod+scene+1.png
      • ken28875K Offline
        ken28875
        Hi Tim,
        Welcome to Sketchucation.
        These are cool renders, but maybe a bit too grainy.
        What rendering engine do you use?
        Cheers!
        _KN
        Follow Your Dreams.
          tktechie
          Thanks for the reply, Ken.
          I've been using Maxwell Render. I like how the settings act similar to a camera setup.
          The one is quite grainy indeed. I didn't give it as much render time as I should've liked. I needed my main rendering machine for other tasks at the end of that weekend. My rendering setup isn't that complex. I've got a mac mini with a quad i7 and 16GB of ram.
          The larger, less grainy render took all of a weekend to get to the point it is. There were a lot of specular reflections from the light fixtures at the ceiling, and the "EXIT" signs added a lot of time, too, with the SSS material.
          TK2
