    [solved] "movin" group into another group (in ruby)
    7 Posts 4 Posters 735 Views 4 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      after hours of trying and searching i have to ask:
      when i have 2 different groups at level 1 in the drawing,
      how can i
      a. "move = insert" group 1 INTO group 2
      b. insert them both into a GROUP 3
      i tried everything i found , but no chance..
      probably i just need a snall kick to understand the syntax, how the structure is and how elements can be transfered.
      thanx
      stan
      • mitcorbM Offline
        mitcorb
        select the group you wish to insert
        control x
        open the receiving group
        Menu>Edit>Paste in Place
        Option to explode the inserted or not your choice
        Move stuff about within the group as you wish
        Close receiving group
        While still highlighted repeat the above steps.
          artmusicstudio
          hi mitcorb,
          very kind from you, but i know the solution in skp itself,
          what i need is a solution in ruby, i just cannot get the group entities into another group..
          but thanx a lot !!!!
          stan
          • mitcorbM Offline
            mitcorb
            ooops I didn't see the request
            My apologies 😳
              CAUL
              I think this works:
              ` def self.add(g0, g1)
              g0.entities.add_instance(g1.entities.parent, g1.transformation * g0.transformation.inverse)
              g1.erase!
              def self.insert(ng, g0, g1)
              ng.entities.add_instance(g0.entities.parent, g0.transformation)
              ng.entities.add_instance(g1.entities.parent, g1.transformation)
              g0.erase!
              g1.erase!
              end`
              • Dan RathbunD Offline
                Dan Rathbun
                You also need to check the group level for attribute dictionaries and materials, and apply (or copy) them to the new copied instances.
                I'm not here much anymore.
                  artmusicstudio
                  hi,
                  thanx! work like a dream,
                  as soon as i found out, that a
                  ng - group must be created before calling the method, then it moves both groups into it.
                  fantastic!
                  THANK YOU !!!!!
                  stan
                  result:
                          g0 = @group_floors #COMES FROM ANOTHER METHOD
                  	g1 = @facade_group #COMES FROM ANOTHER METHOD
                  	ng = model.entities.add_group
                  g0.erase!
                  g1.erase!
                  #ng.name = "master house group created"
                  count = 1
                  entities3 = ng.entities
                  entities3.each { |entity|
                  if entity.is_a?(Sketchup;;Group)
                  entity.explode if count == 1 #SO GROUPS ELEMENTS ARE AGAIN AT LEVEL 1, as needed
                  count =  count + 1
