    Parametric modeling, anyone?
    45 Posts 14 Posters 5.3k Views 14 Watching
    • tkluyskT Offline
      tkluysk
      Hi all,
      we're exploring the possibility of adapting MatterMachine for use in SketchUp, and would like to get some opinions about that from this community.
      MatterMachine is a flow-based parametric modeling engine. Think Grasshopper, or SideFX Houdini. It currently runs in the browser, using Unity3D.
      It's akin to Dynamic Components, but it uses a graph, is more modular, and packs quite a bit more power in general.
      Here are a couple of examples of what that power gives you:
      An intro showing a table configurator and how to model a parametric classic: a shell.
      Modeling a Spiral Staircase
      Below are a few live examples. It's currently best to use Chrome. And you'll be asked to install the Unity3D plugin.
      The /editor links will show the graph.
      Staircases:
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/spiral-staircase
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/spiral-staircase/editor
      http://mattermachine.com/app#machine/ykreci4Y59ktGWkanTY9oh/stair-string
      http://mattermachine.com/app#machine/ykreci4Y59ktGWkanTY9oh/stair-string/editor
      Window & Door:
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/multipanel-window
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/multipanel-window/editor
      http://mattermachine.com/app#machine/ykreci4Y59ktGWkanTY9oh/door-and-doorframe
      http://mattermachine.com/app#machine/ykreci4Y59ktGWkanTY9oh/door-and-doorframe/editor
      Draw people & trees:
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/place-trees-people
      http://mattermachine.com/app#machine/AHnb3ZkNNQcuJst2Z8nVqT/place-trees-people/editor
      We think we can lower the threshold for developing dynamic assets, as well as provide a visual programming alternative to Ruby extensions.
      Let us know if you think it's worth a shot (or not!).
      Tom
      MatterMachine
      • Mike LuceyM Offline
        Mike Lucey
        Watched the videos, quite interesting. I think there could be potential.
        Mike
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Jolran is onto something πŸ˜„
          http://sketchucation.com/forums/download/file.php?id=120641
          • JQLJ Offline
            JQL
            Nice!
            www.casca.pt
            Visit us on facebook!
              DOD3R
              nice indeed
              • jolranJ Offline
                jolran
                Hah, Thanks Jiminy. That one is following around, I see..
                @tkluysk
                It IS an interesting topic.
                I will post a more interesting GIF later so you can see where I'm at using D3.js inside a Webdialog in Sketchup.
                I think it is relevant to the topic. And might be of interest.
                Isent MatterMachine dependent of Crome ? And how can one implement Crome in Sketchup ?
                • jolranJ Offline
                  jolran
                  Hello.
                  Yes, I'm very active working on it. I have spent many month on building the GUI, and now I'm in Sketchup building Node-methods and experimenting..
                  Eric Cheung's work look pretty impressive. Although never saw the GUI, which play a HUGE role in a modeler like this.
                  It get's easily daunting connecting nodes together.
                  So I have spent quite a lot of time on polishing the GUI, with context menus, icon-management, tooltips etc. All which are easily overlooked starting a project like this.
                  Regarding teamwork:
                  It really depends on if I go commersial or not. (I haven't made up my mind on that matter yet.) It depends on the progress. The plugin is not release ready.
                  If I do go commersial, then as you understand Teamwork will be difficult.
                  Was thinking of having 2 versions. 1free and 1 Pro(advanced)
                  But let's keep the topic open, if you wanna PM me or discuss things in the open, be my guest. πŸ˜„
                  I'll probably be banned(can't compress the GIF further) but I post a demo showing an attractor point stearing the scale for some parametric cones. The scaling is dependent on distance from the point by a division. The Cones are originaly spaced out on a Polargrid.
                  • PixeroP Offline
                    Pixero
                    Wonderful. Simply wonderful. πŸ˜„
                    Can't wait to try it out... πŸ˜‰
                      GrassHopper for Sketchup πŸ˜„
                      It will be a plugin or a standalone ?
                      • PixeroP Offline
                        Pixero
                        A plugin.
                        • jolranJ Offline
                          jolran
                          Yes, as Pixero said. However, Pilou you would have to update your specs to at least IE9 for SVG πŸ˜„
                          @tkluysk
                          I thought at first you where an individual seeking to connect Sketchup with another program.
                          I have now looked through some tutorials at your homepage and see that the GUI and the program are quite impressive. It is more a standalone program, whereas I make use of The Sketchup API.
                          So I gather your first ambition simply is to export geometry to Sketchup after having created it in your program ?
                          For hooking it up into a webdialog I see a problem if dependent on Web_GL, as I said. Since Sketchup uses default browser. IE on windows, and there is not much to be done about that, as far as I know.
                          So using as an external program means you will have Sketchup send information to update WEB_GL and then back again to update Sketchup ?
                          Or maybe have you found another backdoor solution πŸ˜„
                          Best regards/
                          Joel
                          • tkluyskT Offline
                            tkluysk
                            Hi Jolran,
                            We're currently using Unity3D as our viewer, and a C# codebase for our parametric engine + operators - which delivers quite good performance in the browser. We're not strictly married to Unity3D, so SketchUp is a really interesting option for us.
                            Too early to say where we will draw the line between SketchUp and our application. There are a few options, from a really tenuous connection, to deep integration.
                            We're using SVG for our graph. AFAIK SketchUp uses WebKit on Mac and IE on PC. MatterMachine should run on both.
                            But we expect some hurdles πŸ˜„ Would be great if you could help us with those, but totally understand you're invested. Respect for what you've done! I kinda know how much work it is πŸ˜‰
                            I'll PM you!
                            MatterMachine
                            • jolranJ Offline
                              jolran
                              Ah .net, I see. That's a different thing then..
                              So if I may ask, have you made any efforts whatsoever getting into Sketchup ?
                              Ok I wait for the PM.
                              • majidM Offline
                                majid
                                Woooow, cant waiting for this.... an huge step forward
                                • tkluyskT Offline
                                  tkluysk
                                  Jolran, your work looks great. And for a big part, complementary. Are you still actively working on it?
                                  For the sake of completeness, I compiled a little list of relevant threads and projects. Please add if you know of any other ones. We might be able to help eachother out and make this happen.
                                  This April fool's led to some intense discussion on the topic:
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=51564
                                  More...
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=51698
                                  http://sketchucation.com/forums/viewtopic.php?t=22713
                                  http://sketchucation.com/forums/viewtopic.php?f=179%26amp;t=11074
                                  http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=52388
                                  Other users of this forum that had a stab at this:
                                  • Jolran's solution seems most mature. No links yet Jolran?
                                  • tbd with SME
                                  • Eric Cheung with his Script Sequencer:
                                  https://vimeo.com/22764739
                                  MatterMachine
                                  • tkluyskT Offline
                                    tkluysk
                                    @jolran
                                    Yes, we've done basic work trying to get a C# <-> Ruby socket working, but we hit a first wall with threads in Ruby.
                                    We're starting a more serious attempt soon.
                                    The SketchUp team has been really supportive sofar, and the community is vibrant, with several relevant and similar projects undertaken by its members, so with everybody's help, we feel confident we can pull it off.
                                    MatterMachine
                                    • JQLJ Offline
                                      JQL
                                      I really feel you guys should PM a lot to each other and talk to the SU team a lot. I feel it's a bit of a waste to not mix both your efforts and you can be sure you'll get a lot of us asking for more!!!
                                      Best of luck to both!
                                      JoΓ£o
                                      www.casca.pt
                                        DOD3R
                                        on JoΓ£os comment
                                        • tkluyskT Offline
                                          tkluysk
                                          Our first phase effort will involve building a working socket to pass data between C# and Ruby/SU. We have a socket going, but there are some issues passing data between the socket thread and main thread in Ruby.
                                          Second issue we're tackling is efficiently pass (or at least display) large amounts of triangles and line segments between MatterMachine and SU. Building 20000 triangles using Ruby takes about a second. That is too slow!
                                          MatterMachine
                                          • JQLJ Offline
                                            JQL
                                            I've just crossed my eyes on the "Cricket for sketchup" thread, (Pixero's fault on Thea Render Forum πŸ˜„) where Thomthom talks about a way to visualize geometric operations before commiting them to actual geometry. This is supposedly faster than that sec you talk about, but I can't understand half of what is being discussed...
                                            Jolran is there discussing it too so you should PM each other even more!
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=51564#p465815
                                            Cheers,
                                            JoΓ£o
                                            www.casca.pt
                                            • 1 / 3
