    Material is deleted when cloning
    13 Posts 3 Posters 811 Views 3 Watching
      Marc477
      Can someone explains why this happens ?
      test = Sketchup.active_model.materials.current
      #<Sketchup;;Material;0x8a19480>
      test2 = test.clone
      #<Deleted Entity;0x8a19278>
      I'd like to store a material in a class variable to use it later, if I do not clone, and the selection change, test will not contain the previous material I want, but the new one selected.
      Thank you πŸ˜„
      • Dan RathbunD Offline
        Dan Rathbun
        I just did the following in SU2014 and got a SPLAT!
        Choose a material that is not in the model.
        Open console.
        test = Sketchup.active_model.materials.current test.name
        Choose a material that IS in the model.
        test2 = Sketchup.active_model.materials.current test2.name
        Everything is fine.
        Now,.. try to get the name of the previous material.
        test.name
        -- > SPLAT
        I'm not here much anymore.
          Dan Rathbun
          Anyway. save the name of the material, and perhaps also it's texture filepath, if it is not yet IN the model.
          Test any material reference for validity before using it. If there is no current material nil may be returned, which evaluates as false.
          if matl && matl.is_a?(Sketchup;;Material)
            # go ahead and use the matl reference in code
            matl_set = Sketchup.active_model.materials
            if matl_set.include?(matl)
              # do something
            Dan Rathbun
            The Ruby methods clone and dup, do NOT yet work upon SketchUp API classes.
            We discussed this in previous topics:
            • Clone PolygonMesh
            • Face.clone
            • Re: Temporarility Changing Materials
              Marc477
              Thank you, I fixed my problem by processing only materials used in the model:
              aMat = Sketchup.active_model.materials.current
              if aMat != nil and Sketchup.active_model.materials.include?(aMat)
              • tt_suT Offline
                tt_su
                We should improve this. But they would not make sense for Entity based classes as instances are persistent and have to be created via entity.add_*.
                • tt_suT Offline
                  tt_su
                  Open console.
                  Everything is fine.
                  test.name
                  -- > SPLAT
                  I cannot reproduce this. Did you submit the splat? Did you include any info I can use to look it up?
                  Do you see this consistently? (Can you do a video recording?)
                    Dan Rathbun
                    I do think I sent in the Splat Report.
                    I do not have video capture software installed (unless it comes with Windows 7?)
                    This was 2 weeks ago... I haven't tried since.
                    • tt_suT Offline
                      tt_su
                      Did you enter any details into the BugSplat? (So we can search for it.)
                        Dan Rathbun
                        I entered the steps that caused the splat, and then copied from the splat dialog, into the above SCF report.
                        • tt_suT Offline
                          tt_su
                          SU2014 Win?
                          • tt_suT Offline
                            tt_su
                            Ah! Found the crash report. And I realized I'd overlooked the last step in your instructions - accessing the name of the first material after it was not current any more. It's another bug where Ruby is allowed to get a handle to a transient material. I'm logging a new issue.
                              Dan Rathbun
                              @tt_su said:
                              Ah! Found the crash report. ... I'm logging a new issue.
                              πŸ‘
