    Material is deleted when cloning
    13 Posts 3 Posters 1.0k Views 3 Watching
    • Dan RathbunD
      Dan Rathbun
      Anyway. save the name of the material, and perhaps also it's texture filepath, if it is not yet IN the model.
      Test any material reference for validity before using it. If there is no current material nil may be returned, which evaluates as false.
      if matl && matl.is_a?(Sketchup;;Material)
        # go ahead and use the matl reference in code
        matl_set = Sketchup.active_model.materials
        if matl_set.include?(matl)
          # do something
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        The Ruby methods clone and dup, do NOT yet work upon SketchUp API classes.
        We discussed this in previous topics:
        • Clone PolygonMesh
        • Face.clone
        • Re: Temporarility Changing Materials
          Marc477
          Thank you, I fixed my problem by processing only materials used in the model:
          aMat = Sketchup.active_model.materials.current
          if aMat != nil and Sketchup.active_model.materials.include?(aMat)
          • tt_suT
            tt_su
            We should improve this. But they would not make sense for Entity based classes as instances are persistent and have to be created via entity.add_*.
            • tt_suT
              tt_su
              @dan rathbun said:
              I just did the following in SU2014 and got a SPLAT!
              Choose a material that is not in the model.
              Open console.
              test = Sketchup.active_model.materials.current test.name
              Choose a material that IS in the model.
              test2 = Sketchup.active_model.materials.current test2.name
              Everything is fine.
              Now,.. try to get the name of the previous material.
              test.name
              -- > SPLAT
              I cannot reproduce this. Did you submit the splat? Did you include any info I can use to look it up?
              Do you see this consistently? (Can you do a video recording?)
              • Dan RathbunD
                Dan Rathbun
                I do think I sent in the Splat Report.
                I do not have video capture software installed (unless it comes with Windows 7?)
                This was 2 weeks ago... I haven't tried since.
                • tt_suT
                  tt_su
                  Did you enter any details into the BugSplat? (So we can search for it.)
                  • Dan RathbunD
                    Dan Rathbun
                    I entered the steps that caused the splat, and then copied from the splat dialog, into the above SCF report.
                    • tt_suT
                      tt_su
                      SU2014 Win?
                      • tt_suT
                        tt_su
                        Ah! Found the crash report. And I realized I'd overlooked the last step in your instructions - accessing the name of the first material after it was not current any more. It's another bug where Ruby is allowed to get a handle to a transient material. I'm logging a new issue.
                        • Dan RathbunD
                          Dan Rathbun
                          @tt_su said:
                          Ah! Found the crash report. ... I'm logging a new issue.
                          πŸ‘
