    Convert Array into Integer
    3 Posts 2 Posters 328 Views 2 Watching
    • R
      rossthompson
      I am trying to use a simple bit of code that allows me to set the color alpha value in SketchUp 7.
      I use this version as its the last one with a free DWG importer.
      Anyway the problem is I can only get an array from 'UI.inputbox' and I need an integer to set the color.alpha value.
      Can anyone correct the code?
      Ross
      ` def translucent
      model = Sketchup.active_model
      materials = model.materials
      m=materials.add("translucent") unless m=materials["translucent"] # Adds a material to the "in-use" material pallet.
      title = 'Opacity'
      prompt = 'Opacity'
      default = 0.5
      result = UI.inputbox([prompt], [default], "text") # need to use array
      UI.messagebox(result)
      m.color = Sketchup::Color.new(100, 100, 100, result) # Specify the colour.opacity
      color = m.color
      alpha = m.alpha=0.5 # Set material transparency
      materials.current = materials["translucent"] # Set to the current material
      Sketchup.send_action "selectPaintTool:" # Start the paint tool
      end`
      • tt_suT
        tt_su
        You need to access the items inside the array. In your case you only have one item so it would be: result[0].
        m.color = Sketchup::Color.new(100, 100, 100, result[0])
        http://rubylearning.com/satishtalim/ruby_arrays.html
        You should also check result to see if the user hit Cancel in the inputbox.
        • R
          rossthompson
          Hi, that has sorted it.
          Thank you
