    Newbie question: extrude following a straight line in space
    8 Posts 2 Posters 603 Views 2 Watching
      mykape
      Hello,
      sorry, I've got a probably quite stupid newbie question:
      I am trying to extrude an aluminium profile along a line
      in space.
      So e.g. my "line in space" goes from 0,0,0 to 5,5,5.
      The "profile" shall be a rectangle of 0.1, 0.1, 0.2
      The "profile" shall hang on the underside of my line
      (exactly in the middle).
      How can I tell Ruby to draw this rectangle perpendicular
      to the "line in space", so I can extrude it afterwards?
      The upper edge of the "profile" would be level with
      the plane of the x and z axis and perpendicular to the
      "line in space"
      It's probably be done with the cross product of my
      "line in space" and a second vector. But how to to
      calculated the projection of the "line in space" on
      the plane (so that I can find out the angle relativ
      to the world axis).
      Or is there an easier way by creating a new coordination
      system with the "line in space" as one of the axises?
      Sorry for my English (which is excellent compared to my Ruby πŸ˜‰.
      By the way, thanks to everybody who invested in the various tutorials
      and postings here - it did help me a lot to get that far!
      Best regards
      Klaus
        Jim
        I do not know your purpose of the plugin, but it seems like you would want to create a ComponentDefinition from the extruded profile so the Component could be re-used without re-drawing it each time.
        Typically, you would draw the extrusion in the definition along an axis, then place the component and rotate it to the desired position.
          mykape
          Hello Jim,
          I got a problem to code it. The principle is understood, but I am not able to get to the code.
          See the picture below:
          First I draw the long line going up (angle and length are different every time, depending on some input parameters, but it's not parallel to any axis).
          Next I would like to draw the two lines left and right, parallel to the red axis.
          Then I would liek to draw more line to make it two rectangles and
          that rectangle I would like to extrude for some mm.
          But I am already stuck at finding out, how to make these first two lines,
          at 90Β° and parallel to the red axis.
            Jim
            If the long line "is not parallel to any axis" then the 2 lines left and right can not be both perpendicular to the long line and parallel to the red axis. The 2 lines left and right must be either perpendicular to the long line OR parallel to the red axis, but not both.
            Do you mean you want the 2 lines left and right to be perpendicular to the long line and parallel to the ground plane?
              Jim
              Hopfully this is helpful:
              model = Sketchup.active_model
              line = model.selection[0]
              w = 2.0
              l = 1.0
              pts = [
                [-w/2 , -l/2 ] ,
                [w/2  , -l/2 ] ,
                [w/2  , 0  ] ,
                [-w/2 , 0  ]
              z_axis = line.end.position - line.start.position
              l_len = z_axis.length
              z_axis.normalize!
              if z_axis == Z_AXIS or z_axis == Z_AXIS.reverse
                x_axis = z_axis.cross(Y_AXIS).normalize
              else
                x_axis = z_axis.cross(Z_AXIS).normalize
              y_axis = x_axis.cross(z_axis).normalize
              tr = Geom;;Transformation.axes(line.start.position, x_axis, y_axis, z_axis)
              pts.map!{|pt| pt.transform!(tr)}
              face = model.entities.add_face(pts)
              face.reverse!
              face.pushpull(l_len)
                mykape
                Hello Jim,
                this is great, thank you very, very much! I see a long way of
                learning ahead of me πŸ˜‰
                I can continue with my program now!
                However, just out of curiosity:
                Why do I need to use a different axis for the cross product
                if the selected line is very steep, or rather why
                exactly 1/64th is the true/false - point? Testing it,
                the extruded from flips by 90Β°, but I can't get my
                head around it - why?
                Best regards and thanks again!
                Klaus
                  Jim
                  The 1/64 I may have made up, or borrowed from the AutoCAD arbitray axes formula. It is probably not needed. It should work to simply compare the line to the Z_AXIS. If the line is the Z_AXIS, we need to use another axis in the cross product calculation.
                    mykape
                    Ah! ok, then I understand it.
                    Thanks again!
