    Starting a process in background using Ruby system()
    8 Posts 5 Posters 2.2k Views 5 Watching
    • Al HartA
      Al Hart
      I couldn't find anything else about this in the Forum, so I thought I would pass it along.
      In previous versions of SketchUp, we used Win32API to start processes.
      We changed all these to use the Ruby system() command for SU 2014.
      Sometime we want to start a process where ruby does not wait for it to complete.
      You can do this with the DOS start command:
      system('start ' + scommand_line)
      The the program in the command line will execute and ruby will continue without waiting for it. (Note the command line contains the name of the .exe and also some command arguments)
      However, due to quirk with "start", this fails if the command line starts with double quotes. I found this comment on the web:
      "START has a peculiarity involving double quotes around the first parameter. If the first parameter has double quotes it uses that as the optional TITLE for the new window. "
      So, just adding a blank set of double quotes fixed our problem. This works whether the command line actually starts with a double quote or not
      system('start "" ' + scommand_line)
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • tt_suT
        tt_su
        Wow, that's one of them thing that could have you stuck for hours. Thanks for sharing!
        • Dan RathbunD
          Dan Rathbun
          ... but it is PC only correct ?
          I'm not here much anymore.
          • sdmitchS
            sdmitch
            How do you handle folder name with spaces?
            cmd = "c:\program files\..."
            system('start "" ' + cmd)
            produces an error message which says that Windows cannot find 'c:\program'
            http://sdmitch.blogspot.com/
            • Dan RathbunD
              Dan Rathbun
              given:
              cmd = "c:\\program files\\..."
              one of::
              system( "start \"#{cmd}\"" )
              or:
              system( %[start "#{cmd}"] )
              or:
              system( "start", %["#{cmd}"] )
              or:
              %x[start "#{cmd}"]
              See Ruby docs on literal strings:
              http://ruby-doc.org/core-2.0.0/doc/syntax/literals_rdoc.html#label-Strings
              • sdmitchS
                sdmitch
                @dan rathbun said:
                given:
                one of::
                or:
                or:
                or:
                %x[start "#{cmd}"]
                Thanks Dan. Each of these options do not fail but they do not succeed either. What I was trying to do is create a plugin that would allow me to pick a plugin from a list and create a .rbz file from it using the command line version of 7Zip. This is the final solution
                zip = "c;/program files/7-zip/7z";
                rbz = "c;/users/public/sketchup/plugins/dummy tool.rbz";
                rb = "c;/users/public/sketchup/plugins/dummy tool.rb"
                cmd = "\"#{zip}\" a -tzip \"#{rbz}\" \"#{rb}\""; puts cmd
                #system( "start  \"#{cmd}\"" )
                #system( %[start "#{cmd}"] )
                #system( "start", %["#{cmd}"] )
                #system( %x[start "#{cmd}"] )
                • D
                  driven
                  some zip program require the .zip extension, so you could try using rename...
                  I'm on a mac, but maybe something like...
                  zipped = "c;/users/public/sketchup/plugins/dummy tool.zip"
                  cmd = "\"#{zip}\" a -tzip \"#{zipped}\" \"#{rb}\""; puts cmd
                  %x('start "" ' + cmd)
                  File.rename(zipped, rbz)
                  john
                  • sdmitchS
                    sdmitch
                    john
                    Not a problem with 7-Zip.
                    The -tzip sets the output format.
