    Zoom Window Tool [REQUEST]
    4 Posts 3 Posters 403 Views 3 Watching
    • JClementsJ
      JClements
      Is there a way to replace SU's native Zoom Window Tool with a new graphic which is a crosshair so that the starting corner of the tool can be accurately placed?
      OR
      Could a script create a tool identical to the functioning of the native SU Zoom Window Tool which uses a cross hair graphic?
      • J
        Jim
        Entirely possible - I have the code already to make the selection with cross-hairs. Just need help calculating where to move the camera. Ideas, anyone?
        • Dan RathbunD
          Dan Rathbun
          Make a class Rect inside your tool class (which is instantiated with the picked rectangle.)
          Have instance methods return it's height and center (in screen pixels.)
          Save a ref to the current camera eye:
          cam = view.camera eye = cam.eye
          Calculate a new target as the center of the pick rectangle:
          target = view.inputpoint(*rect.center).position
          Calulate the new up vector from the directional vector
          dir_vec = eye.vector_to(target) up = ? # use trig ?
          Set the camera:
          view.camera.set( eye, target, up )
          Set the zoom factor, by:
          dividing the view.vpheight by the pickrect's height to get the zoom factor to pass as the argument to view.zoom( view.vpheight / rect.height )
          I'm not here much anymore.
          • J
            Jim
            Here is the non-working tool which needs the do_zoom() method filled in.
            https://gist.github.com/jimfoltz/15b0178ad353a6f7a845
