    Webdialog to ruby encoding issue on OSX
    22 Posts 5 Posters 930 Views 5 Watching
      slbaumgartner
      @driven said:
      @ Steve
      do you think the two are unrelated?
      john
      It's possible they have the same cause, but I am not sure how to prove that.
      The man page for the locale command says:
       LANG         Used as a substitute for any unset LC_* variable.  If LANG is unset, it will
                    act as if set to "C".  If any of LANG or LC_* are set to invalid values, locale
                    acts as if they are all unset.
      So the behavior you get is consistent with LANG not being set by SU when it launches a subshell. Also, if you set ENV[LANG] to a specific locale such as "en_US.UTF-8" in the Ruby Console before doing the %x, the other variables all follow.
      So far as I can tell, SU doesn't launch a separate process for a WebDialog (at least I don't see one reported in Activity Monitor). I don't know what environment a WebDialog gets...can it be read from javascript?
      Steve
        driven
        @tt_su said:
        So this only happen on OSX, not on Windows?
        hi TT
        did you get a chance to run this on your mac?
        and did it confirm what I state, on your setup?
        john
        • 2 / 2
