    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 108.9k Views 41 Watching
    • deaneauD Offline
      deaneau
      Mine is this one! πŸ˜„
      La Douce
      By franΓ§ois Schuiten
      http://www.bd-best.com/bgfiles/la-douce.jpg
      And anoter last version...(I had some re readers β˜€
      look like this one
      EDIT: oops not really
      http://upload.wikimedia.org/wikipedia/commons/d/dc/520_class_loco-South_Australia-1984.jpg
      my favorite dieselloco is this one.
      http://www.romecon-expert.de/bluetiger.jpg
      and here a german steam loco
      http://bahnamateurbilder.startbilder.de/1024/uebernommene-stromlinienlok-aufarbeitung-geplant--51088.jpg
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • deaneauD Offline
        deaneau
        @elibjr said:
        Wow! After reading these posts, this is one of the most promising productive plugins I have seen for Sketchup since I started using the software in 2009. Keep up the good work and someone will complete a whole Hollywood movie using your plug-in (with many others). I won't be able to do anything with it for the next few weeks but, this could be packaged with Vali Architects Instant Site Grader Nui and Plusspec to do a complete city. Awesome! πŸ‘
        look here: eneroth have design a table top in sketchup
        http://eneroth.port0.org/models/trains/
        http://eneroth.port0.org/models/groBendorf/ <---
          dtrarch
          Hi Deaneau
          Big Boy is being restored to be fully functional as we speak. πŸ‘ πŸ‘
          Check this out
          http://www.latimes.com/travel/deals/la-trb-big-boy-steam-locomotive-las-vegas-salt-lake-city-20140127-story.html
          What a scene to see this one run.
          dtr
            dtrarch
            youtube of Big Boy #3985 rolling. πŸ‘ πŸ‘
            http://www.youtube.com/watch?v=ZVcOPIaekOU πŸ˜„
            dtr
            • deaneauD Offline
              deaneau
              @dtrarch said:
              Hi Deaneau
              Check this out
              dtr
              is a fictional city. the building looks like bavarian (southern germany).
              • deaneauD Offline
                deaneau
                dtr
                yes this look so marvelous. the horn sound a little bit hoarse.
                • eneroth3E Offline
                  eneroth3
                  You can all make models of these locomotives and share here πŸ˜„ . Remember that they might need to be quite low detailed to avoid lag, you can check out how the rolling stocks shipped with the plugin are drawn πŸ˜„ .
                  My website: http://julia-christina-eneroth.se/
                  • eneroth3E Offline
                    eneroth3
                    Ok About the Pop UP Menu πŸ˜‰
                    I will just add that to the Documentation πŸ˜‰
                    About the number of lines : no problem I have them! (mΓͺme les lignes vides sont numΓ©rotΓ©es! πŸ˜‰
                    About the Cancel : that is made πŸ˜„ (But synonym πŸ˜‰
                    I really don't understand how you manage to get it wrong all the time. It's not a synonym. It's a translation of the word in another context. Another, faulty, word doesn't make sense. If the translation doesn't make sense it' to no help at all. It's only harming the plugin.
                    Also Apply seems to be translated to Appliquer in this context. Can you please explain how you managed to get completely different words? I really want to know because I just can't understand it. Have you never seen a dialog box like the one above?
                      Sorry but in French It's strictely the same thing!
                      "Abandonner" = I close this dialog box and continue my way! πŸ˜„
                      But don't worry that is not matter because i put your version for your pleasure! πŸ˜„
                      • eneroth3E Offline
                        eneroth3
                        It's not just about these 2 phrases. It's about everyone in the whole plugin (230 of them) and every sentence in the whole so called translation of the documentation.
                        If you run this in the console, what does it return?
                        UI.messagebox "TEXT", MB_YESNOCANCEL
                        It's not "strictly" the same. Different words are used in different contexts. It's strictly wrong with other inconsistent words.
                        I have no idea how you do it when you so called translate. When you see strings such as "OK", "Cancel" and "Apply" under the header "Web dialog buttons" in the dictionary file, how can you not recognize those words from similar dialogs?
                        Btw, you've also managed to color the x axis green several times in the so called translation of the documentation. That makes your statement that the so called translation is perfectly understandable to French people a lie.
                        • deaneauD Offline
                          deaneau
                          is it possible to change the value m/s about more than 50m/s?
                          this would be great for take offs
                          dean
                          • eneroth3E Offline
                            eneroth3
                            dean
                            I scaled the slider so it would be easier to run at low speeds at rail yards but you can enter much higher values in the text box πŸ˜„ .
                            I don't know if I should re-scale the slider so it can be used for high speed trains or perhaps even make it logarithmic or something so it can be used for both. That could however be less user intuitive when the user for instance want to double the speed and tries to drag the slider twice as far from its start.
                            • deaneauD Offline
                              deaneau
                              dean
                              no no i dont mean the slider him self. ok this is a way when i can insert an other value.
                              no problem
                              dean
                              • BoxB Offline
                                As a side note to this excellent plugin, it is incredibly hard to make accurate translations of technical language. Not only do you need to be fluent in both languages you also need to be fluent in the relivant jargon of the technology involved. I speak 6 languages and can order a beer in several others but I haven't joined any of the foreign language sections because I know how easy it is to get it all screwed up. My wife works as a similtanious translator in 3 languages and she has translated quite a number of help files/user manuals etc and even she has problems to get it right. We often spend hours rereading and discussing the nuances of phrases and words that can have a multitude of meaning and therefore an almost infinite number of possible target words.
                                You must understand what needs to be said in both languages, if you aren't fluent in one it will be wrong!
                                • eneroth3E Offline
                                  eneroth3
                                  This is very true and one of the reasons I from the start was quite unsure whether I wanted it translated or not. I've tried to explain in my post how important it is to look at the text in its context but I don't know if everyone understood.
                                    Innacurate Green x corrected! πŸ˜„
                                    • BoxB Offline
                                      QED
                                        Quod Erat Demonstrandum, synonym of CQFD in French ? πŸ˜‰
                                        QED Text Editor ?
                                        QED File type of QUEMU ?
                                        QED (quantum electrodynamics)
                                        QED Egypthian first name ?
                                        QED theater's play ?
                                        Q.E.D. TV Serial
                                        Q.E.D Acid Black Cherry Album?
                                          little test
                                          • eneroth3E Offline
                                            eneroth3
                                            I don't know how to say this.
                                            I don't want you to fix the examples I give you of what is wrong. They are examples to show you that you clearly do not understand what you are trying to translate. You don't seem to understand English. I don't know if you batter the text through Google Translate or what you do with it but it's like you don't even read it. Words mean totally different things in different contexts. Canceling a meeting and canceling a dialog are for instance different things. If you do not even recognize these terms I do dot trust any phrase you have translated. Your translation attempts are only causing me problems. Sorry.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
