    Searching a plugin to show real triangles
    3 Posts 2 Posters 316 Views 2 Watching
    • alexandre skA Offline
      alexandre sk
      Hello guys!
      I remember to see a plug-in that show the real triangles of the faces, like in blender, kerkythea also shows it. I am not talking about the hidden geometry button. It's good to see the real triangles to make lighter models.
      I can't find it.
      Maybe you guys can help me. Thanks!
      • tt_suT Offline
        tt_su
        I have an old script that will let you inspect on a per face basis:
        http://sketchucation.com/forums/viewtopic.php?t=21472
        There is no function in SketchUp that let you turn such a display on permanently. Not unless you recreate all the faces triangulated - but that's a one way route.
        Then you have my Model Info plugin that will make a triangle count:
        http://sketchucation.com/forums/viewtopic.php?p=293079#p293079
          alexandre sk
          Thanks Thomthom
          I had your Model info but did not realized it shows the real triangles count.
