    Visualizer for SketchUp
    extensions
    157 Posts 37 Posters 122.9k Views 37 Watching
      ct200224
      Hey, I'm having a lot of trouble locating Visualizer plugins on my SketchUp.... It doesn't seem to be showing up at all. Here's a picture of my plugins folder in SketchUp 2015 with Visualizer installed:
      http://puu.sh/pZQ0t.png
      at path /Users/[yourname]/Library/Application Support/SketchUp 2015/SketchUp
      SketchUp 2016 folder (w/o visualizer, duh):
      http://puu.sh/pZQ5X.png
      at path /Users/[yourname]/Library/Application Support/SketchUp 2016/SketchUp
      Can someone help me at least locate the file?
      Maybe someone could just upload the files so that I can manually download them? Please?
        driven
        if you run this in 'Ruby Console' it will move a copy for you into the v16 User/Library...
        If you read through the thread, you should have seen that the v15 path is for the HD/Library...
        v15_folder = "/Library/Application Support/SketchUp 2015/SketchUp/Plugins/ImaginationVisualizer"
        v15_extension = v15_folder + '.rb'
        v16_folder = File.expand_path("~") + v15_folder.sub('5', '6')
        v16_extension = v16_folder + '.rb'
        command = 'ditto ' + v15_folder.inspect + ' ' + v16_folder.inspect + ' && ' + \
        'ditto ' + v15_extension.inspect + ' ' + v16_extension.inspect
        system(command)
        john
        • F Offline
          Fred*1
          Hello
          I'm still trying to install Visualizer 1.3 on a Mac running El Capitan 10.11.5 with SketchUp v. 16.1.1451
          Can anyone give me step-by-step instructions? Or point me to some?
          Thanks!
            driven
            Visualizer will not install in SketchUp v16 without tricking it to do so...
            temporarily renaming SketchUp 2016 folder in Finder to SketchUp 2015 will allow the download to make the the v15 files...
            once downloaded, change the name back and run the ruby code posted in the post above...
            john
            • F Offline
              Fred*1
              Thanks, driven, for this help. I find, though, that I don't have a folder called "SketchUp 2016" on my Mac. Do you mean in the applications?
              I had SU 8 until now and recently upgraded to SU 2016, in case that makes a difference.
              • F Offline
                Fred*1
                Quick clarification: the folder SketchUp is in on my Mac is just called "SketchUp".
                  driven
                  Applications/SketchUp 2016 is the one I refer too...
                  john
                  • F Offline
                    Fred*1
                    Got it. Thanks!
                    I was able to install it. Thanks for your help!
                    • W Offline
                      willanie
                      Hi Fred,
                      Just so its clear, because I didnt think it was possible. You managed(with John's help) to get Visualizer installed on a Mac with only Sketchup2016 installed.
                      • F Offline
                        Fred*1
                        Hi willanie
                        Yes, that's correct, and I was glad to see that Visualizer works fairly quickly on my MacBook Pro Retina 13" 2014, with 2.8 GHz Intel Core i5 and 8 GB 1600 MHz DDR3 RAM.
                          ste7ana
                          Does anyone know if there is a 32bit Visualizer version available? Thanks
                          • W Offline
                            willanie
                            There is no 32bit Visualizer version
                              ste7ana
                              😞 thanks willanie
                                tmt0009
                                Hello,
                                I have installed Visualizer 1.3 and it works with 2015 (on MAC OS). However there are two issues.
                                The first, is that anytime I close out of the program while modeling it generates a crash report.
                                The second issue is that it doesn't appear in the Library/Application Support/SketchUp2015/SketchUp/Plugins folder which means I can't copy the Visualizer folder or the ruby file over to the SketchUp 2016.
                                Anyone have any ideas? Anything would help. Thanks in advance.
                                T.
                                  ct200224
                                  @driven: Thank you! Thank you so much! It's now up and running nicely!
                                    AristosOntwerp
                                    Hi Pilou,
                                    Quoi faire, si je n'ai pas 2015 comme voi de migrer. J'ai une installation frais de 2016 et installer Visualizer c'est impossible (Vous n'avez pas SketchUp 2013, 2014 ou 2015).
                                    Est-ce que tu a un trick pour cela aussi?
                                    Merci en avance,
                                    Aristos
                                      AristosOntwerp
                                      Does something like that work on Windows 7 as well? I tried with renaming the 64-bit program directory from SketchUp 2016 in SketchUp 2015 - but that was apparently too easy... Still the message: You need 2013, 2014 or 2015....
                                      Aristos
                                      john
                                      • W Offline
                                        willanie
                                        Im pretty sure you must at least install 2015 with windows OS.
                                        Here is a link to sketchup forum posting for getting 2015 Make.
                                        Link to download SketchUp 2015 Make
                                        hello everyone, does anyone have a link to download sketchup make ? i kept searching but only found sketchup 2015 Pro.
                                        SketchUp Community (forums.sketchup.com)
                                          @aristos
                                          Visualizer fonctionne aussi sur la 2015 avec au moins les versions de Window 8 et windows 10 que j'avais installées!
                                            Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 ! 😮
                                            • 6
                                            • 7
                                            • 8
                                            • 7 / 8
