    Ruby c extension and Sketchup Objects
    8 Posts 4 Posters 1.0k Views 4 Watching
      Marc477
      I created a ruby c extension and I know how to use primitive types (int arrays...) as parameter in the functions I created in c.
      But is there any way to use a Sketchup object in a parameter? (like an entity) How can I decode the VALUE on the c side? Do I need a struct that fits the EXACT implementation of the object? Can I find that implementation?
      Thank you
        Marc477
        Ok I found a way to achieve that. Here is an exemple with the Sketchup class Geom::Point3d
        static VALUE AddOne( VALUE self, VALUE p1 )
            VALUE point;
            VALUE rbGeom, rbPoint3d;
            float x,y,z;
            //Convert to c float
            x = NUM2DBL(rb_funcall( p1, rb_intern( "x" ), 0 )) + 1;
            y = NUM2DBL(rb_funcall( p1, rb_intern( "y" ), 0 )) + 1;
            z = NUM2DBL(rb_funcall( p1, rb_intern( "z" ), 0 )) + 1;
            //Convert back to ruby VALUE
            rbGeom = rb_define_module( "Geom" );
            rbPoint3d = rb_define_class_under( rbGeom, "Point3d", rb_cObject );
            point = rb_funcall( rbPoint3d, rb_intern( "new" ), 3, rb_float_new(x), rb_float_new(y), rb_float_new(z) );
            return point;
        This code takes a Point3d as parameter, adds one to each value and return the resulting Sketchup ruby object.
        • tt_suT Offline
          tt_su
          You might want to make sure the user passed a Point3d object to your function.
          Chris Lalancette got a nice series that digs into creating Ruby C Extensions:
          http://clalance.blogspot.no/2011/01/writing-ruby-extensions-in-c-part-1.html
          We recently released Ruby C++ Extension examples that include Visual Studio and Xcode projects as well as the exact binaries we use for SketchUp:
          https://github.com/SketchUp/ruby-c-extension-examples
            Anton_S
            I find this point conversion useful, along with SketchUp Ruby C Extension / src / Example - Basics / SXBasics.c by Thom, which demonstrates conversion from SU Point3d to C.
            Is there a way to check if passed item is a Point3d object?
            Edit: I think it really doesn't matter because user may also pass their custom point3d classes or just an array. The rb_funcall( v_point, rb_intern("x"), 0 ) should do the job and raise an error if v_point doesn't respond to .x method.
              Anton_S
              Also, is SketchUp Length class handled well when it comes to converting it using NUM2DBL, or I should first convert it to float before passing to a c extension?
                Get a reference tot he Geom::Point3d class and invoke a call to is_a? or kind_of?.
                  Yes. Prior to SU2015 Length was hacked to be a subclass of Float. Now - that's not really possible in Ruby, but it was still done. πŸ˜„
                  In 64bit Ruby that broke and we had to change it, it is now a Numeric which forwards to Float. Because of duck typing NUM2DBL should work.
                    Anton_S
                    Thank you Thom.
