    [Plugin] s4u_Explode
    10 Posts 7 Posters 8.9k Views 7 Watching
    • hdpvH Offline
      hdpv
      s4u_Explode v2.0.1
      Explode all Groups, Components, Curves in selected Groups or Components to lines and faces.
      http://sketchucation.com/pluginstore?pln=s4u_Explode
      http://extensions.sketchup.com/en/content/s4u_explode
      Tutorial video:
      -Fix error
      s4u_Explode v1.1.1
      25/06/2014
      fix error
      s4u_Explode v1.0.0
      07/05/2014
      Suforyou
      http://www.sketchupforyou.com
      • F Offline
        function
        great stuff, thanks hdpv
        • OxerO Offline
          Oxer
          Thanks for the plugin, I created theSpanish Language File.
          Spanish Language
          http://www.oxervision.blogspot.com/
            What is supposed to do ?
            I select my component ( a simple box)
            I press the Icone of the Plugin Explode
            And... nothing! ๐Ÿ˜ฎ (2014 PC)
            Ah ok : i have a Component B (Cylinder) inside a Component A
            After I have only on a component A with the objects of the component B
            But nothing is explosed! Except the Component B
            Does it's that ?
            • hdpvH Offline
              hdpv
              Hi Pilou!
              it only explore all Component and Group IN Components(or Groups)
              Carefuly explore Component.Make unique! ๐Ÿ˜„
              Thanks Oxer!
              Suforyou
              • P Offline
                Pherim
                Hello, I would like to have a version of this plugin (or another plugin) that only explodes all curves in the selection and also inside groups or components, but leaves the groups and components intact.
                • ludnidL Offline
                  ludnid
                  @hdpv said:
                  Hi Pilou!
                  Thanks Oxer!
                  Appreciate your hardwork man. As I understand it, this plugin of yours is free. Is there a particular reason why it now asks me to update each time I click on it when I have no reason to? Especially when the plugin still functions as it is meant to?
                  If you don't ask, the answer will always be no.
                  • hdpvH Offline
                    hdpv
                    Please check again.
                    Suforyou
                      laowang
                      Hi hdpv!
                      Thank you for your extension!It's February 4,2022.When I use this extension, there will be a messagebox "Check for extension updates!".But I see there is no update here.So what should I do?
                      • hdpvH Offline
                        hdpv
                        I updated it.
                        Suforyou
