    Get registry string from ruby 2.0
    8 Posts 2 Posters 1.2k Views 2 Watching
    • Al HartA
      Al Hart
      There are a lot of threads about this, but I am getting confused.
      I took a look at Win32Api.rb in SketchUp 2014, and it says:
      "Win32API is deprecated after Ruby 1.9.1; use dl directly instead"
      Do I took a look at DL, and it says:
      "DL is deprecated, please use Fiddle"
      So I took a look at Fiddle, which does have some Win32 stuff, but I couldn't find an example on how to get a string from the registry using Fiddle.
      Can someone post, or point me to a Ruby 2.0 example which will run in SketchUp and read a Windows Registry String?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • Dan RathbunD
        Dan Rathbun
        The standard library has a Registry class BUT it is currently bugged with regard to string encodings.
        If you wish to be backward compatible you can still use the Win32API class, which in Ruby 1.9.1+, becomes a wrapper to the DL class (which is more C-like,) which in Ruby 2.x, becomes a wrapper to Fiddle.
        There should be examples in the CHM or embedded in the ruby scripts that load them (the CHM help docs are generated from inline documentation.)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          If you wish to do this from a C/C++ extension, you can:
          include "Winreg.h" (include "Windows.h"),
          load the "Advapi32.dll" library,
          and use the registry functions.
          The pages on individual functions have examples.
          http://msdn.microsoft.com/en-us/library/ms724875(v=VS.85).aspx
          These are the functions you'd call using DL, Win32API or Fiddle if you go that route.
          Add: These ways are more complicated, as you must first open a handle to the registry key before a calling read, and be sure to call close on the key when done (like in an ensure clause! )
          • Al HartA
            Al Hart
            Thanks Dan, this looks great.
            Let me try it out
            Al Hart
            • Al HartA
              Al Hart
              Thanks Dan - that works!
              Is there anything similar for Ruby 1.8, or do I need to continue to use Win32API.so to read the registry?
              Al Hart
              • Dan RathbunD
                Dan Rathbun
                WHAT works ?
                (I talked about at least 3 ways.)
                IF you went with the low level system calls, via Win32API class then you use the "Win32API.rb" wrapper script that comes with Ruby 1.9.x and higher.
                As I said, ... for Ruby 1.8.6, you use the "Win32API.so" (and/or "win32ole.so",) files ("lifted from the Windows Installer package",) that I posted in the "Plugins" forum. (Use the Author Index Sticky post to find it.)
                • Dan RathbunD
                  Dan Rathbun
                  You can ALSO instead use the WIN32OLE class ("win32ole.rb" all lowercase,) and instantiate a ref to a Windows Scripting Host object, which has SAFE functions to access the registry.
                  http://msdn.microsoft.com/en-us/library/x05fawxd(v=vs.84).aspx
                  Something like this (tested):
                  module MyCode
                    def self.sketchup_install_location()
                      require "win32ole"
                      wsh = WIN32OLE.new("WScript.Shell")
                      begin
                        val = wsh.RegRead("HKLM\\Software\\Wow6432Node\\SketchUp\\SketchUp 2014\\InstallLocation\\")
                      rescue WIN32OLERuntimeError
                        val = wsh.RegRead("HKLM\\Software\\SketchUp\\SketchUp 2014\\InstallLocation\\")
                      wsh.ole_free
                      return val
                  Add: The value returned (in my test.) is "UTF-8" encoded, which is a good thing.
                  FYI: The path to the key for SketchUp < 2013 is under:
                  "HKLM\Software\Google\Google SketchUp 8\InstallLocation\"
                  etc. for older versions.
                  But "win32ole.so" does not come with older version of SketchUp. You will need to provide a 1.8.6 compiled versions of the so file. [url=http://sketchucation.com/forums/viewtopic.php?t=42732:27osqac0]It is posted (by me,) in the "Plugins" forum[/url:27osqac0].
                  šŸ’­
                  • Al HartA
                    Al Hart
                    @dan rathbun said:
                    WHAT works ?
                    We wound up using win32ole and RegRead
                    However we ran into problems with an uncaught exception when the Registry Key we passed did not exist, so we added a second rescue for the second registry key.
                    Like this (I added XX to the key to intentionally make it fail)
                    require "win32ole"
                    begin
                    	val = wsh.RegRead("HKLM\\Software\\Wow6432Node\\SketchUpXX\\SketchUp 2014\\InstallLocation\\")
                    	val = ""
                    end#begin/rescue
                    if (val == "")
                    	begin
                    		val = wsh.RegRead("HKLM\\Software\\SketchUpXX\\SketchUp 2014\\InstallLocation\\")
                    		val = ""
                    	end#begin/rescue
                    end#if
                    wsh.ole_free
                    puts "VAL; " + val
                    Al Hart
