    Overwritten script!!!
    5 Posts 4 Posters 510 Views 4 Watching
    • bomastudioB Offline
      bomastudio
      I accidentally overwritten a file *.rb with a *.html (generated by the script) that is loaded at this time in SU. Is there a way to recover it?
      • eneroth3E Offline
        eneroth3
        How can something.html overwrite something.rb? The file names differs.
        My website: http://julia-christina-eneroth.se/
        • Dan RathbunD Offline
          Dan Rathbun
          It seems like he wrote the HTML file using the ".rb" extension, instead of the ".html" extension.
          This could happen by using __FILE__, instead of:
          File.join( File.dirname(__FILE__), File.basename(__FILE__,".rb"), ".html" )
          I'm not here much anymore.
            Dan Rathbun
            It might help (in the future,) to use an editor with an auto-backup feature.
              driven
              did you type it directly into 'Ruby Console' and is the session still open?
              if so, you can use the 'up arrow' to go back to it, otherwise it's a learning experience...
              EDIT: should have read the post in detail first, but I'll leave this up for others...
              if your on linux what editor did you write it in, most have history...
              john
