    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Talk] Ruby Debugger for SketchUp 14+
    45 Posts 8 Posters 6.6k Views 8 Watching
      Jim
      The debugger shows the filename and line number of .rbs files. It will not show the contents of the file.
      It can, however list variable names and values in .rbs files.
      I have not tried to set a breakpoint on a .rbs, so I am not sure if it is allowed. But i found the debugger will follow observers into .rbs files.
        slbaumgartner
        @avariant said:
        I haven't had a chance to look at the debugger yet but the first thing I thought when I read about was, is this a backdoor that can be used to defeat the .rbs encrypted rubies? Does the debugger reveal anything about the current line of execution, or does it just deliver line numbers? When displaying data about a variable, does it volunteer variable names or does it just respond with a value?
        I would be very disappointed to find out it did. ๐Ÿ˜•
        You raise some very interesting questions.
        If, as I suspect, the rbs unscrambler is an SU facility that decodes the rbs before handing it to a standard Ruby interpreter, then the plaintext source and all other aspects of your plugin would indeed be visible to the debugger. Exploiting this hole isn't as easy as it might sound, since you have to somehow stop Ruby at a breakpoint before the ide commands will work - a bit like shooting in the dark - but I can see that some clever person may find a way.
        I think this may come down to how SU implements the debugger ide library. That is, the ide could detect that the source file is rbs and refuse to debug it. This is possible because the SU debugger library implements the ide protocol itself, it does not use the standard debug interface or Gem.
        Steve
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          rbs files aren't safe anyway. There are rbs unscramblers.
          I tested one to see how safe rbs would be, and it works reeaaally well. It outputs a perfectly clean rb file.
          So yeah, I would not protect sensitive stuff with that.
            slbaumgartner
            This falls into the realm of the old cliche "locks only keep honest people honest". The decryption key and code for rbs are necessarily embedded in the SketchUp application, and the same key is used for all rbs files. Any competent hacker can easily defeat the rbs scrambling. As JBB points out, several have already published code to do so.
            So the question isn't whether rbs is secure (it clearly is not), it is whether you believe there are enough dishonest people in the world that you will lose significant intellectual property value when they unscramble your rbs. The same question applies to the potential backdoor via the debugger.
            Steve
              Trogluddite
              The debugger is exposing nothing new here, the same thing could be done anyway through any of the SU consoles by any savvy Rubyist - using nothing but standard Kernel method calls. Setting trace functions and using the returned bindings to read local and instance variables, get the current method and its call signature, read the call stack etc... can all be done from even the most basic install of Ruby.
              You can't actually read the code lines unless they are in a 'plain text' source file (the scrambler presumably 'evals' the unscrambled code, which precludes seeing the source) - but there's not much that can be done to secure the other information without losing the consoles - which would make life very difficult for the amateur developers that we all rely on for our toys!
              • 3 / 3
