    Combination, Scene, Layer - Done!
    6 Posts 3 Posters 491 Views 3 Watching
      If not yet existing πŸ˜„ Sdmitch has done! 😎 see following posts!
      Number of schemas : N
      Layers: Number of schemas (+1) - Each schema is on one layer
      Scenes: Number (+1) of possible combinaisons of schemas / Layers
      Scene 0 = All Schemas - all layers visible
      Scene 1 = First Combinaison of Schema = only Layers of combinaison 1 visible
      Scene 2 = Second Combinaison of Schema = only Layers of combinaison 2 visible
      Scene 3 = Third Combinaison of Schema = only Layers of combinaison 3 visible
      etc...
      Example : 3 schemas by twice by twice wanted
      so 1-2, 1-3, 2-3
      Scene 1 = First Combinaison of Schema: 1-2 = only Layers of combinaison 1 visible
      Scene 2 = Second Combinaison of Schema: 1-3 = only Layers of combinaison 2 visible
      Scene 3 = Third Combinaison of Schema: 2-3 = only Layers of combinaison 3 visible
      Example : 4 schemas by twice by twice wanted
      so 1-2, 1-3, 1-4, 2-3, 2-4, 3-4
      Scene 3 = Third Combinaison of Schema: 1-4 = only Layers of combinaison 3 visible
      Scene 4 = Fourth Combinaison of Schema: 2-3 = only Layers of combinaison 4 visible
      Scene 5 = Fifht Combinaison of Schema: 2-4 = only Layers of combinaison 5 visible
      Scene 6 = Sixtht Combinaison of Schema: 3-4 = only Layers of combinaison 6 visible
      Example : 4 schemas by 3 by 3 wanted
      so 1-2-3, 1-2-4, 2-3-4
      Scene 1 = First Combinaison of Schema: 1-2-3 = only Layers of combinaison 1 visible
      Scene 2 = Second Combinaison of Schema: 1-2-4 = only Layers of combinaison 2 visible
      Scene 3 = Third Combinaison of Schema: 2-3-4 = only Layers of combinaison 3 visible
      etc... following Number of Schemas by combinaison wanted!
      Many Thanks by advance! 😎
        Like this πŸ˜„
        • sdmitchS Offline
          sdmitch
          Plugin ComboScenes has been uploaded to the Plugin Store.
          All operational questions should be PM'ed to Pilou. I don't use them I just write them!
          http://sdmitch.blogspot.com/
          • JQLJ Offline
            JQL
            That's what the A-Bomb scientist said once...
            www.casca.pt
            Visit us on facebook!
              Excellent! πŸ‘
              Bravo to Sdmitch! 😎
              Plugin Combo Scenes
              Only 8 objects for SU V8! No restriction for newer versions!
              Select any "Components and / Or Groups" "with or without names" (named is better! )
              Make a scene of your all objects (not necessary but better for you! πŸ˜„
              Call the plug : enter your number of combination "object by object" wished and you will obtain Scene / Layers named of any possible cominations!
              You can even enter 1 ! So you will obtain a named scene / layer for each objects!
              Scenes result are zoom extended
              Of course be reasonable of Number / Combination! πŸ’š
              Here 2 x 2 from 4 objects was asked! (only 2 scenes results shown following from the 6 possible! )
                An hell's puzzle πŸ˜„
                Carreful : even you find a volumic solution, that don't want to say that is possible in reality! πŸ€“
                Give all the 2 pieces starting πŸ˜„
                puzzle_v6.skp
