    Error in sketchup
    22 Posts 5 Posters 2.5k Views 5 Watching
    • G Offline
      Gábor
      @john2 said:
      Gabor - my plugins were manually downloaded in chrome and copy pasted in sketchup version 8 and as TIG said those don't get recognized by plugin store since they are not downloaded via store interaface. I'm not understanding your statement. 😕
      John,
      I suppose you have the SketchUcation Pluginstore Plugin installed? ( http://sketchucation.com/resources/plugin-store-download )
      If yes, and you launch it, you will see a list of the latest 20 plugins. If in the first dropdown you select the "Full list" option, it will show you the list of all plugins available in the PluginStore.
      If you scroll down in this list to the plugin what you want to install and press the "Autoinstall" button, the plugin will be installed. It will also register your PluginStore download and next time you'll be able to see this new plugin in your Bundles list.
      • john2J Offline
        john2
        @gábor said:
        John,
        I know this, are you being sarcastic? 😐
        @pbacot said:
        Looks like one of your problems is the rotated box tool. If you look in the SUcation Store, it was last updated last year. So perhaps it isn't compatible. Each entry gives an update date. However that doesn't mean it won't work. Looks like you had problems with two plugins, and their names are in the error report.
        Unfortunately you'll have to look around for more info on the tool--the link in the SUcation store for more info on the rotated box tool is bogus.
        So a search in the forum gives this: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=45806 Oh it's been updated. Just didn't make it into the store yet.
        On Compo Spray You can see in the store it has not been updated in a long time. My process was, click to the Forum thread. Look at the latest entries--another person has the same problem--and no answer is given. You can assume this one will continue to give you trouble. I also checked at the ruby "library depot", where D. Bur also offers plugins, and it is not updated there.
        So what should I do to use these 2 plugins for sketchup 2014? Or there is no way? The only way is to downsave your file to version 8 and then work? 😞
        • 2 / 2
