    Location API
    7 Posts 3 Posters 816 Views 3 Watching
    • F Offline
      FlyingPikachu
      File > Geo-location > Add location...
      New to SketchUp and Ruby. Is there any API to modify this^? I want to auto-select an adjacent area to mine and grab it.
      • Dan RathbunD Offline
        Dan Rathbun
        See the ShadowInfo hash object:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/shadowinfo
        I'm not here much anymore.
        • JuantxoJ Offline
          Juantxo
          I'm not sure what are you asking, but to import large google earth image there are several methods:
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=40627%26amp;hilit=terrain+mesh
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=40413
          http://sketchucation.com/forums/viewtopic.php?f=271%26amp;t=6867
          http://a4chitect.webng.com/
          If you download Skelion plugin, there is a feature to make a mesh of an area, (no image satellite), using NASA’s SRTM Elevation data.
          SketchUp ruby API does not have methods to add locations.
            Dan Rathbun
            True, instead you set the "TZOffset", "Latitude" and "Longitude" attributes of the model's ShadowInfo hash.
            The SketchUp API also has Geom::LatLong and Geom::UTM class objects.
            • F Offline
              FlyingPikachu
              Couldn't find such a feature in Skelion, but that grid generator looks interesting!
              Doesn't TZOffset only change the time zone? Also changing Latitude/Longitude only let me get two models of the same locations side-by-side. Here's my test code:
              mod = Sketchup.active_model # Open model
              shadowinfo = mod.shadow_info
              shadowinfo["Latitude"] = shadowinfo["Latitude"] +0.001
              shadowinfo["Longitude"] = shadowinfo["Longitude"]+0.001
              shadowinfo["TZOffset"] = shadowinfo["TZOffset"]+0
              UI.messagebox("Latitude; " + shadowinfo["Latitude"].to_s +
              "\nLongitude; " + shadowinfo["Longitude"].to_s +
              "\nTZOffset; " + shadowinfo["TZOffset"].to_s)
              Thoughts?
              • JuantxoJ Offline
                Juantxo
                It's a pro feature. Just click mountains icon.
                Add relief Skelion feature
                • F Offline
                  FlyingPikachu
                  Thanks! Unfortunately this didn't give me the level of detail I'm after (can't zoom in far enough).
