Location API
7 Posts 3 Posters 600 Views
  • F Offline
    FlyingPikachu
    File > Geo-location > Add location...
    New to SketchUp and Ruby. Is there any API to modify this^? I want to auto-select an adjacent area to mine and grab it.
      Dan Rathbun
      See the ShadowInfo hash object:
      http://www.sketchup.com/intl/en/developer/docs/ourdoc/shadowinfo
      I'm not here much anymore.
        Juantxo
        I'm not sure what are you asking, but to import large google earth image there are several methods:
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=40627%26amp;hilit=terrain+mesh
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=40413
        http://sketchucation.com/forums/viewtopic.php?f=271%26amp;t=6867
        http://a4chitect.webng.com/
        If you download Skelion plugin, there is a feature to make a mesh of an area, (no image satellite), using NASA’s SRTM Elevation data.
        SketchUp ruby API does not have methods to add locations.
          Dan Rathbun
          True, instead you set the "TZOffset", "Latitude" and "Longitude" attributes of the model's ShadowInfo hash.
          The SketchUp API also has Geom::LatLong and Geom::UTM class objects.
          • F Offline
            FlyingPikachu
            Couldn't find such a feature in Skelion, but that grid generator looks interesting!
            Doesn't TZOffset only change the time zone? Also changing Latitude/Longitude only let me get two models of the same locations side-by-side. Here's my test code:
            mod = Sketchup.active_model # Open model
            shadowinfo = mod.shadow_info
            shadowinfo["Latitude"] = shadowinfo["Latitude"] +0.001
            shadowinfo["Longitude"] = shadowinfo["Longitude"]+0.001
            shadowinfo["TZOffset"] = shadowinfo["TZOffset"]+0
            UI.messagebox("Latitude; " + shadowinfo["Latitude"].to_s +
            "\nLongitude; " + shadowinfo["Longitude"].to_s +
            "\nTZOffset; " + shadowinfo["TZOffset"].to_s)
            Thoughts?
              Juantxo
              It's a pro feature. Just click mountains icon.
              Add relief Skelion feature
              • F Offline
                FlyingPikachu
                Thanks! Unfortunately this didn't give me the level of detail I'm after (can't zoom in far enough).
