    [Plugin] Add comments to your file
    104 Posts 20 Posters 22.2k Views 20 Watching
    • inteloideI Offline
      inteloide
      Hello Greenskp,
      Everything is working fine on my computer.
      According your screen recorder, you have an issue "$ not defined" : it looks like jquery is not working correctly. Also, the height of the area where to enter text is smaller than expected.
      Please try to install again the plugin. Sometimes it works.
      If you have the same error, replace the pt-br.js file you send me by the previous version.
      Keep me informed.
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • greenskpG Offline
        greenskp
        I replace with pt-br.js file that i sent to you and worked very well!
        Do you think about include in the Plugin Store on next update? I am really happy and waiting to tell my colleagues about all features.
        • greenskpG Offline
          greenskp
          Hello Inteloid, it's me again
          i was working today and i found some bugs in 2.3.9 version.
          1. Double click or Ctrl + mouse click doesn't open a hyperlink
          2. After change a language, if i change again, the javascript side remains the same and just Localization.rb does the change.
            I erased the Library and Comments_2.3.9 and reinstall both, also i cleaned the cookies on Internet Explorer but this behaviour remains.
          3. The last tab and penultimate tab doesn't save if not contain an image annexed.
            Seilo
            @bmoffa said:
            I would really like to use this plug-in, but it seems to not save or not load comments that I add. At first it lost comments from one of the two tabs I set up, then it lost everything.
            I'm using version 2.3.5 in SketchUp 2015 Pro 64 bit (current build). I really hope you can fix this as I really like it.
            Hi, I'm having the same problem as BMoffa. The data in Tab1 is always deleted after I close and reopen a file. Tab2 seems to be fine...
            Using version 2.3.10 on a 64Bit Win7 machine
            • 6
            • 6 / 6
