    Find Corners within given proximity of other corners
    5 Posts 3 Posters 343 Views 3 Watching
      mrapsouthern
      Is there a plugin that will allow me to find corners that are within a given distance of each other?
      For example a third party piece of software I have can give the following information about a sketchup model. This issue with it is that I have to go back to sketchup to "merge" the points somehow. As sketchup doesn't number the corners and planes like this it can be VERY tedious to find the offending corners.
      I'd like to do this check in sketchup directly, with the corners highlighted somehow.
      "Corner 1045 is nearly (within 10 mm) same as 1039 in plane 570
      Corner 1032 is nearly (within 10 mm) same as 516 in plane 562
      Corner 506 is nearly (within 10 mm) same as 505 in plane 562"
      Thanks in advance
      • sdmitchS Offline
        sdmitch
        ThomThom's CleanUp might help http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=22920
        Are planes the same as SketchUp layers?
        http://sdmitch.blogspot.com/
        • cottyC Offline
          cotty
          Thomthoms vertex tools can merge within a given distance...
          my SketchUp gallery
            mrapsouthern
            Thanks,ThomThom tool done it better than I could have imagined. Just saved my weekend! !
            • cottyC Offline
              cotty
              Fine! If you like you can support his cookie jar...
              my SketchUp gallery
